10-08-2019, 06:41 AM | #1 |
75
Rep 383
Gunge or Plug
In the event of a puncture should I use the gunge as provided or am I better getting an aftermarket plug kit?
Everthing goes to Entropy in this Age.
10-08-2019, 09:13 AM | #2 |
73
Rep 293
I've had my tyres repaired with a plug kit, problem free, however I'd recommend going to a mechanic instead of doing it yourself. First it can be dangerous if not done properly (tyre can explode at higher speeds), second you won't be able to take the tyre off the rim without a proper machine anyways.
10-08-2019, 09:26 AM | #3 | |
75
Rep 383
10-08-2019, 07:38 PM | #4 |
129
Rep 421
Drives: 2020 X2 M35i, 2005 Volvo V50T5
Use the gunge only in a true emergency. Your tire guy will have to go scoop it out of the tire and rim before fixing it, and he/she will thank you for not using it It throws off the wheel balance badly, so that's another reason to avoid using it.
I would never try using a plug at roadside. To do that successfully means rasping the edges of the puncture, applying a solvent, and pulling the treated plug strings through properly. You don't want any dirt or debris in there... |
nonot15.00 |
10-10-2019, 07:48 AM | #5 | |
73
Rep 293
If it is more than a puncture, spare tyre/rft/tow truck are the only reasonable options. |
10-10-2019, 11:56 AM | #6 | |
75
Rep 383
