10-07-2019, 06:44 AM | #1 |
9
Rep 31
Control Second and Third Row Seats from Driver Seat
Odd question but I haven’t figured it out. Is there a way to control the AC in the second and third row from the driver’s seat? Have the Cold Weather Package and want to be able to control the climate control in the back rows from the driver’s seat. I am sure this is in the iDrive somewhere, but not sure where.
Thanks. |
10-07-2019, 08:19 AM | #2 |
134
Rep 475
If you activate the 'sync' option in AC, whatever the driver settings are, it will be mirrored in all the other zones I believe. I have 'sync' set to a shortcut on the 1-8 numbers.
2014 A207 E550 Vert
2018 F60 Countryman S All4 2019 G07 X7 40i |
10-07-2019, 08:55 AM | #3 | |
293
Rep 341
If my post was informative or helpful, please click the appreciate button. Thank you.
10-14-2019, 08:51 PM | #5 |
26
Rep 44
Or just press the AC menu button in the center of the dash between the two front seat temp controllers. This is a shortcut button that will take you directly to the climate control menu in iDrive.
10-24-2019, 08:37 AM | #6 |
Rep 26
What do you mean you have it shortcutted? Every time I go in the menu and select sync, it only lasts for that drive. When I get back in it is no longer synced. Please tell me, as this has really been frustrating to me.
10-24-2019, 09:19 AM | #7 |
177
Rep 431
Drives: 2020 x7 M50i
When you are in that menu to sync it, you have the option of holding one of the radio preset buttons 1-8 to set that button as a “shortcut” button for the function. I used number 2 on mine. You can also use this technique to shortcut various options to give you a quick way to activate a setting that otherwise requires multiple steps to do.
10-24-2019, 05:03 PM | #9 | |
Rep 26
