Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > My adventures with an chinese eBay CIC camera emulator
      10-04-2019, 02:13 PM   #1
osunick
Drives: 2002 Honda S2000 w/oem hardtop
Posting this in case it helps others.
I installed one of these and had it coded:
https://cgi.ebay.com/ws/eBayISAPI.dl...=2187712529017
Had a black screen. Tried a separate video source to isolate the issue. No joy.
Found a wiring diagram:
https://www.aliexpress.com/item/32693569047.html
Turns out my PNP harness had the camera pinned to the euro pins, and the US ones were different. Repinned harness. Laptop works on input, no camera. I noticed at this point that the battery was low in the car. I assumed from the incessant hacking to install both this and a combox.
Connected rearview camera, still a black screen. Checked camera power wire on the emulator. 0v. Turned off car, and the multimeter was still connected. 12V! Turns out the power wire on the emulator was only powering the camera when the engine was off, and that would explain the battery drain.
Anyone know how I can get a carsystems emulator? This thing is junk.
-n.
      10-04-2019, 10:42 PM   #2
lnxguy
357
Drives: 2009 335D
Why not use the Autofocustech emulator? Lots of us are using it without issue.
https://www.ebay.com/itm/Reversing-I...sAAOSwoudW3SSD
'09 335D
      10-06-2019, 11:26 AM   #3
osunick
Thanks for the autofocustech link. I ended up ordering an emulator directly from aliexpress to see if that resolves the power issue. Also, the back and forth with the ebay seller is pretty funny, after seeing the autofocustech listing it's clear that he ripped off that one and removed the watermarked images, including the one with the all important pin outs. I let them know and maybe ebay will sort it out. Also, despite claiming that nobody had issues, looking at the ebay feedback this is patently untrue. My fault for not looking more closely.
      10-07-2019, 02:41 PM   #4
lnxguy
357
Drives: 2009 335D
Hopefully you get it figured out.
'09 335D
      07-17-2020, 10:08 PM   #5
apirumann
apirumann's Avatar
74
Drives: 2011 E93 335i, 99 E46 323i
Have you ever figured this out? I think I have the same problem.
      07-19-2020, 12:52 PM   #6
osunick
I just wired the damn thing to be always on with ignition. And then I talked Bimmertech to sell me their module without a camera for $400. Now it works perfectly and I have dynamic lines on the display.
      07-23-2020, 02:00 PM   #7
apirumann
apirumann's Avatar
74
I wish I was that lucky. The emulator I had drained my battery because it was waking up the car every 5 minutes.
      08-05-2020, 09:50 AM   #8
ccfj1
Tinkerer
ccfj1's Avatar
United Kingdom
83
Drives: F25 X3 M-Sport
Power the camera from the reverse lights, that should fix it.
2014 F25 X3 335d M-Sport:
