10-03-2019, 10:21 PM | #1 |
Rep 11
1st Time Living in the Snow
Hey all!
I recently moved in the PNW and haven't decided yet if I'll be staying long term. In the meantime, I would like to take advantage of the snow since it's as short as a 35 minute drive from Seattle. I have a 2018 M40i with 21" wheels on summer tires which is all I needed when I lived in California. Would I be able to get away driving the summer tires and carrying cables/chains if needed? Or is it necessary I get a new set of wheels with winter tires on? Go easy on me, I'm a noob! |
10-03-2019, 11:57 PM | #2 | |
262
Rep 769
10-04-2019, 12:05 AM | #3 |
2171
Rep 1,346
The "glass transition" begins at about 40 degrees, meaning your summer performance tires will behave like hockey pucks at that temperature or below. Protect yourself and your investment with some dedicated winter tires. Note: Seattle gets more ice than snow so a good ice tire would be preferred. Plus, people don't drive that great in Seattle in the winter, stay home if it's really icy or the roads are snow covered.
To the Seattle people: No offense! Note: Research glass transition and tires. Tire Rack will be helpful. Last edited by ContactPatch; 10-04-2019 at 12:14 AM.. |
Alias1431795.00 |
10-04-2019, 05:54 AM | #4 |
6614
Rep 2,323
Drives: 9Y0 Cayenne S
If it were me I would put all season tires on and avoid chains or cables. The extra hardware is a pain to install and remove and can damage the vehicle if not properly installed or if they fail. I have driven in snow and ice for 40 years.
10-04-2019, 07:02 AM | #5 | |
4696
Rep 6,047
So, what to do? If you were going to remain in a low snow (5"/year) city, such as Seattle, you could probably do well with either a set of dedicated winter tires, in your case, probably the "performance winter" variant (Blizzak LM or Michelin Alpin), or try the new Michelin CrossClimate+ all weather tire (different from all season), noting that it carries the snowflake symbol. If you're going into snow covered mountains for skiing etc., true winter tires (Blizzak WS or Michelin XIce xi3) are advised. Read this for more information: https://www.tirerack.com/tires/tests...y.jsp?ttid=231 Again, the one thing not to do is rely on Summer tires in winter. For ease, keep in mind, some tirerack.com installers will store your off-season set of tires. You just roll in for quick swap....unbolt one set, bolt on the other....like a "pitstop".
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
IM_ALL_IN57.00 |
10-05-2019, 08:44 AM | #6 |
Rep 18
Experienced Winter Driver
New England has a wide variety of winter driving conditions. I've had numerous cars, trucks and SUVs. As a skier, I look to drive in Winter storms.
Here in the NE, snow isn't the worst surface. What's really tricky are the variable conditions where road surface ranges from, almost dry black ice, to slush, packed snow, freezing rain. First of all, 21" wheels with low-profile AS tires are going to be abysmal for winter driving. The biggest problem is they'll be completely unpredictable. If you had narrow tire/wheels, and some skill, you might get away with AS tires for limited winter use but, not 21" 275s. As many other's point out, winter tires have a much softer compound that's designed for slippery, wet conditions. This is probably more important than the aggressive tread. Winter conditions are hell on wheels (and brakes). Cold temperatures and salt wreck havoc. It won't take long to pit your 21" rims. And, don;t forget to wash you brakes often with soap to get the salt off (I usually stop at a self-serve car wash at the end of each winter drive). If you want to drive in winter conditions get a set of 18" (yes they fit) or 19" low-cost wheels and mount them with proper snow tires. It won't take long for the ROI. If you leave for non-snowy areas then, you can sell them on CL easily. Another option, if you only plan on skiing a few times a year and, otherwise don't plan on driving in winter conditions it to rent a zip car for skiing. |
Sportstick4696.00 |
10-05-2019, 05:31 PM | #7 | |
69
Rep 127
Sportstick4696.00 |
10-05-2019, 07:18 PM | #8 |
57
Rep 120
Agree with others when they say summer tires are a no go. I purchased an alternate set of 20" winters(695) last year and they were great. Having two sets makes it super convenient and there's no chance of the dealer jacking my rims up.Temps are beginning to flirt with 40 here and I'm looking forward to putting the 695's back on. Get new tires at a minimum and another set of wheels if the cash is available...nothing worse than a fully capable winter vehicle being crippled by the wrong tires.
Sportstick4696.00 |
10-07-2019, 02:17 AM | #9 | |
795
Rep 1,959
