SOS Malfunction with No Sound / Chimes - Cannot Diagnose
10-02-2019, 11:17 AM | #1 |
Rep 9
Hello,
I'll apologize upfront for being another post about this issue out of the hundreds or thousands but I've reviewed as many posts, videos and discussions that I can in my free time along with troubleshooting without any success. I've recently acquired an '08 335i which has the SOS malfunction error. Upon inspecting the trunk there was a MOST bypass loop on the satellite radio connector. Thinking that maybe the loop is bad, I ordered a new one from amazon. Troubleshooting wise I started at the amp and worked through the modules. Amp has yellow blinking LED, connector has the red optical light for signal. Plug that in and move to the Bluetooth module. Connector has signal, plug into the module and move to the satellite radio. Connector has signal plug it into the module and move to the termination under the dash. This is where the signal is lost. There is no light here. Makes sense, module is more than likely faulty. Replace the MOST bypass loop with the new one I purchased and lo and behold, the signal still is not present at the final termination. I tested the bypass loop on the Amp connector just to confirm the signal will still travel to the other modules and it does. Checked the MOST BUS that is under the driverside rear bolster but it all looks untouched/not tampered with. I truly am at a loss, I haven't come across a post where the final termination did not have signal of any kind. Bypassing the Amp as previously mentioned does not complete the loop, the final termination still remains without signal. Any and all help is highly appreciated, Fuses I haven't entirely checked as what is listed on the paper in the glovebox for radio, several are not present in my fusebox from factory. |
10-02-2019, 12:09 PM | #2 |
151
Rep 185
Just after all the units in the trunk, there is a MOST bus junction block on the rear right shock tower.
https://www.newtis.info/tisv2/a/en/e...xi-lim/RQGaWrH You can access it by removing the rear left passenger bolster. Just pull firmly near the top and it should pop off. Check that the MOST cables are properly connected. And that the signal from the satellite radio is coming into the block. From there, the signal travels down the driver's side of the car to the diag port. If it's making it out of the block then it may be a broken fiber optic cable. |
10-02-2019, 12:41 PM | #3 | |
Rep 9
The fiber optic lines are run and terminate at this block as mentioned, is there anyway to actually troubleshoot it like the module connectors that provide the red optical light? Here (I hope it works) is a picture of the bus block. OEM tape is still there and looks like it has never been tampered with. |
10-02-2019, 01:51 PM | #4 |
1911
Rep 13,104
If you shine a light source in one end of a good fiberoptic you will see it
on the other end if the fiber is good. Nobody has reported them being bad other than one guy who had rodents chew threw some. Shinning a light in one end and mapping where is goes might help you better visualize the routing. |
10-02-2019, 01:59 PM | #5 |
151
Rep 185
The optical cables are fairly fragile.
So if the car was serviced and someone mis-handled the cable(s), the internal glass fiber could be broken and you wouldn't be able to tell. You will need to carefully remove the one going to the diag connector at the front of the car to see if the red light is exiting the block. If you do see the light, then you need to check the cable going to the diag connector. It's possible that the cable is broken near the front of the car - in or near the footwell since that's where a lot of work can be done and something disturbed / broken. |
10-02-2019, 02:29 PM | #6 |
151
Rep 185
Sorry for the duplicate posts.. I think the maintenance they've been doing caused me to post duplicates.
I've reported myself to the mods Hopefully they'll come in and clean up the mess. Last edited by Canuck335; 10-02-2019 at 05:25 PM.. |
10-02-2019, 02:50 PM | #7 |
1911
Rep 13,104
You can shine a light source down the fiberoptics to trace where they
go. Also modules must be powered up to re transmit the signal to the next module . I suggest you label the cables to reduce confusion. If you have a TCU there may be a Mulf module underneath it which also has its own fiber connection. |
10-02-2019, 05:03 PM | #8 |
1911
Rep 13,104
You can't bend them at 90 degrees but they are not super
fragile. You might want to delete 4 of the 5 duplicates you put up. to Canuck335. I realize this site has been wacky lately. |
10-02-2019, 05:35 PM | #9 | |
Rep 9
Regarding both your suggestions to shine a light source through the fiber, are you referring to the runs that terminate at the block i posted earlier? From my understanding and experience with fiber optics in networking, if it is terminated in a block, it isn't as simple as unplug/plug the run in again, but rather uses specialized tools to terminate into a junction. Feel free to correct me, but I'll get the easy part out of the way and check if there are any extra modules that I didn't see. Appreciate the help guys, really hope I can track down the issue. |
10-02-2019, 05:36 PM | #10 |
151
Rep 185
In case you haven't seen this, page 28 of this PDF has a nice, friendly diagram of the MOST cable routing.
And some diagnostics / troubleshooting instructions on page 30. https://www.e92n55.com/wp-content/up...us-systems.pdf Last edited by Canuck335; 10-02-2019 at 05:42 PM.. |
10-02-2019, 05:39 PM | #11 | |
Rep 9
Let's assume the run to the diagnostic port is broken along the path. Is there a possibility of having a short fiber optic run from the same block which simply terminates into a loop? Not having to go the distance to the diagnostic port? I recognize that to the diagnostic connector, it has more than just the fiber optic run to it. |
10-02-2019, 05:48 PM | #12 |
1911
Rep 13,104
The OBD connector is not the Fiberoptic test point.
The fiberoptic test point is connecter to the dash undercover and only is a junction to access the Most Loop with another Fiber Line. The fiber lines are separated inot individual lines at the Most Hub. Where they plug into the modules there is a plug in connector that holds both the In and Out Line . See the second link under Most to see the diag connector picture. Logic 7 https://www.e90post.com/forums/showthread.php?t=1056432 http://www.bmwlogicseven.com/?p=3837 http://www.bmwgm5.com/ https://www.e90post.com/forums/showt...5#post24455335 http://www.e90post.com/forums/attach...2&d=1260829447 http://www.google.fr/url?sa=t&rct=j&...slMu2A&cad=rjt https://www.bmwgm5.com/Logic7_E90_91_92_93.htm http://www.bimmerfest.com/forums/sho...d.php?t=982666 http://www.e90post.com/forums/attach...1&d=1209780605 Most http://www.e90post.com/forums/showthread.php?t=727663 http://www.e90post.com/forums/showthread.php?t=347222 https://www.google.com/search?q=BMW+...VCkMqy2aCK09M: http://www.1addicts.com/forums/showt...php?p=19256760 https://www.teacremotes.com/bmwgm5/ https://www.e90post.com/forums/showthread.php?t=347222 Most problems with the Most bus modules can be solved but rotating a Most Bus jumper through the positions. Also a fully loaded Most Bus setup will include possibly the SAT module a TCU and maybe Mulf module typical added into the loop on page 28 of the Electrical pdf 1 electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU this will have and in and out line. Last edited by ctuna; 10-02-2019 at 06:00 PM.. |
10-02-2019, 05:51 PM | #13 | ||
151
Rep 185
So the signal has to travel from the diagnostic port back to the radio somehow. |
10-02-2019, 06:58 PM | #14 | |
Rep 9
The culprit was the bastard underneath the bluetooth module, so I'm guessing the MULF? As soon as I looped that, I got light at the diagnostic port. Not only that, the chime, radio and everything along with it Appreciate all the help gents. While I have you here, what exactly is the MULFs purpose? AUX appears to be grayed out as well, is that an entirely different issue? Bluetooth connects successfully and can make calls etc; Is this the only function I can do with it connected? I was hoping to run music via bluetooth. Again, really can't appreciate it enough |
10-02-2019, 06:59 PM | #15 |
Rep 9
I take that back, quick google search revealed MULF has to do with AUX.
In that regard, if I were to source another MULF module, does it require any kind of BMW coding to the VIN? Or am I lucky enough to just plug and play |
10-02-2019, 07:10 PM | #16 |
1911
Rep 13,104
Unless you were incredibly lucky its not going to be plug and
play. At the very least the Vin number in the module has to be changed to match your car. It's pretty cheap to get a coding diag setup. Unfortunately Most Bus programing on cars after 3/07 builds need and Icom cable to code Most Bus modules. At least that is what Most say this is kind of a nebulous subject. Not nailed down to the 3/07 date but that is what most say. |
10-03-2019, 08:28 AM | #18 | |
Rep 9
I'm going to be checking tonight. Are there any indicators on the module itself to show that it is receiving power (LED's)? When referring to the fuse diagram, it shows radio being one of several things, would you happen to know the fuse for the MULF? |
10-03-2019, 10:59 AM | #19 |
98
Rep 121
The MULF2 module provides USB and AUX to the center console. The easiest way to know if it's getting power and functioning is to pull the MOST connector and to look for the red light. If there's no light, you can check for power by putting a multimeter across pin 17 (+12V) and pin 36 (ground) of the 54 pin connector. From my understanding, those units most often are damaged by water since they're hanging upside down under the TCU, on the floor of the trunk. Was there any water collected there?
I've read both that it needs to be coded and it doesn't; it cannot be coded by K+DCAN in your car though. I wasn't able to retrofit a MULF2 into my car and eventually gave up, but you might not need to since you're replacing one in your car instead of retrofitting. If your MULF2 is bad, you might be able to get one cheap from the junkyard, those are often left behind as people strip the cars for parts since they're not worth much. A lot of them are water damaged though... If you plug it in and have no luck, it probably needs coding. Unless you can find someone with an ICOM, it's not worth programming since the cost of an ICOM is more than the cost of a CIC/combox retrofit... I recommend the CIC/combox retrofit but it's pricey. Instead you can pick up a cheap headunit aux port off ebay and code 6FL out of your car; this is only about $20 but you'll lose USB functionality. Look for the aux port with the white 12-pin connector. |
10-03-2019, 11:24 AM | #20 |
1911
Rep 13,104
Mulf might work without programming as bluetooth and SOS
are currently handled by the TCU. The cleaner install would be to remove the TCU all together and use the use the Mulf 2 hi or combox for both the bluetooth phone and USB. I had a TCU go bad and no USB on an 06 so I used the following as a replacement. http://www.e90post.com/forums/showth...4#post23244354 Some Mulf related info http://www.e90post.com/forums/showthread.php?t=1181654 http://www.e90post.com/forums/showthread.php?t=1344811 http://www.e90post.com/forums/showth...5#post19088745 Mulfs can be found on ebay and buy and sell here. Mulf fuse can be found in the cluster of Radio and telephone fuses . They make it hard to tell which one. Keys to the Kingdom in the following link. georges links https://www.bimmerfest.com/forums/at...9&d=1539905743 |
10-03-2019, 03:54 PM | #21 | |
98
Rep 121
04-28-2021, 02:30 AM | #22 |
2422
Rep 1,770
Drives: Bmw 330i and Bmw 328i
Whats the issue or why do these most cables fail? Do people get codes and idrive or audio shutting off because of it? Is that the only symptoms?
Tags |
audio, chimes, malfunction, most system, no sound, sos |
