N54 stuttering when building boost/under load
10-02-2019, 07:23 AM | #1 |
24
Rep 192
I noticed this issue a few hundred miles ago, where if i were to give the car some throttle, towards high rpm it seems like the turbos arent pushing as much boost and the power seems to come in and out, and if i were to bring the rpm's past 5500-6000 rpm the i would almost always get a check engine light
I ordered new boost solenoids( not installed yet) but is there something else it could be? E90 335i 135k miles
N54 e90 335i
10-02-2019, 01:43 PM | #2 |
165
Rep 247
If not throwing any codes, I would check to see if diverted valve is fully seated and locked. I had same issue and my diverted valve was coming off. I pushed it all the way back in and locked it and have been issue free.
10-02-2019, 01:51 PM | #3 |
165
Rep 247
10-03-2019, 07:39 AM | #6 | |
24
Rep 192
I havent pulled them for sure but i feel that im getting low boost then the engine light comes on
N54 e90 335i
10-03-2019, 08:01 AM | #7 |
611
Rep 1,272
A reasonable expectation. If you know that, then you know you should be smoke testing?
10-03-2019, 08:04 AM | #8 |
611
Rep 1,272
Actually, hold on. When you say "check engine light", do you mean the half engine light or the Service Engine Soon Light? Cause 30FF throws half engine, not SES.
10-03-2019, 08:06 AM | #9 |
611
Rep 1,272
Just pull the codes already. Why would you not start with that?
Antetokounmpo1551.50 |
10-03-2019, 08:50 AM | #10 | |
24
Rep 192
I havent plugged in my scan tool when i have the code as it goes away when i restart the engine It doesnt always come up when driving
N54 e90 335i
10-03-2019, 09:58 AM | #11 |
24
Rep 192
Half engine light. It only shows up on the little screen, not a service engine soon light
N54 e90 335i
10-03-2019, 12:00 PM | #12 |
654
Rep 1,893
The code is stored, whether you see the light on start up or not. Read the codes.
The first thing you always want to do is read the codes. There is no point to more speculation about what might have caused the lights on your dash to go on or off. Just read the codes. |
10-04-2019, 02:53 PM | #13 | |
24
Rep 192
30ff for sure. Just checked all the codes
N54 e90 335i
10-05-2019, 05:45 AM | #14 | |
654
Rep 1,893
What are you checking codes with? What are your engine mods? If you have MHD make a log. If you don't have MHD, get it and make a log. It is also useful to install BMW standard tools on your laptop (bimmergeeks.com) and learn how to use them. They provide the ability to perform sophisticated diagnostic testing for short money - software is free and all you need is a $40 cable. Or you can just throw parts at this until you're broke. There are a number of possible explanations for your failure to meet boost target (30FF) including leaks in the vacuum lines, boost solenoids, wastegate actuator, diverter valves. But there are other explanations and you really don't provide enough information for anything but a guess. Make a log. |
10-05-2019, 09:13 AM | #15 | ||
24
Rep 192
Im using inpa. And 30ff is for sure not the only code its throwing, but the most significant. Im getting codes like (not quoted, but off the top of my head) alternator problems. Forgot exactly what it was but around that And what would mhd tell me exactly for $40?
N54 e90 335i
10-05-2019, 09:14 AM | #16 | ||
24
Rep 192
N54 e90 335i
10-06-2019, 05:59 AM | #17 | |
654
Rep 1,893
One of MHDs most useful functions is logging. If you don't know what that is, do some reading on this forum. |
10-06-2019, 06:15 PM | #18 | ||
24
Rep 192
Hm. Weird
N54 e90 335i
10-08-2019, 10:42 AM | #20 | |
233
Rep 564
If you want to Flash maps/tunes it will be $100. Upgraded tunes/map packs are another $50. Don't start modding your car though until you've done a bunch of maintenance. |
