Passenger side mirror no moving.....?
10-02-2019, 06:55 AM | #1 |
2001
Rep 3,731
For some reason the passenger side mirror on my "new to me" 07' 335i hasn't worked since I got the car. I can't adjust the mirror, and it won't fold in either...nothing. I've done a little research on the forums, and checked fuse #21 and #27.....both are good.
Any other ideas before I start diving in deeper and pulling the mirror all apart? Hopefully it's something easy that I'm just missing? |
10-02-2019, 07:56 AM | #2 |
263
Rep 1,225
Is the mirror adjustment switch set to the left (driver side) or right (passenger side)?
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
10-08-2019, 06:54 AM | #4 |
2001
Rep 3,731
Well, at this point I'm thinking there might be a connector unplugged somewhere. Is there a plug in the mirror housing, or it it somewhere inside the door? Since I'm not getting any movement at all from the passenger side mirror.....
Any other ideas?
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
10-08-2019, 07:44 AM | #5 | |
2341
Rep 3,539
Not sure if you may be aware but these cars are plagued by these mirrors unfolding past their stop point. So a lot of guys cut the white wire (i believe) that disables the folding all together in order to avoid this issue. Root cause is that the stopper pin develops surface corrosion. When you fold the mirrors in, the pin is pushed up and doesn't come down during unfolding operation. At that point motor doesn't know when to stop and keeps going past its normal stop point. This could be your issue if the previous owner simply cut a few wires while trying to figure out which one was dedicated to the folding operation. It's worth a look see. Cheers Last edited by Wolf 335; 10-08-2019 at 10:19 AM.. |
10-08-2019, 09:21 AM | #6 | |
2001
Rep 3,731
10-08-2019, 09:36 AM | #7 |
Rep 3
