Expansion Tank
10-02-2019, 04:21 PM | #3 |
204
Rep 525
Our cooling systems are self bleeding. Just keep adding coolant until it stops taking it. There's no need to crack a bleeding screw open or anything like that.
10-02-2019, 06:59 PM | #4 |
13
Rep 63
Yes, you'll need to bleed the system. Be ready for coolant to pour out of the lower hose when you disconnect it, assuming you still have a fair amount of coolant left in the car. After replacing my tank, I filled the system back to the max level in the expansion tank, bled the system, and checked the level again, filling with more coolant as necessary.
Do you know what caused the need to replace the expansion tank? For me, it signaled my water pump was going bad. |
10-03-2019, 01:16 PM | #6 | |
204
Rep 525
If you are a DIYer and don't mind pouring your coolant, there is no need to bleed. After a few moments of observation, anyone who has passed middle school physics could understand how it's self bleeding, the bleeding screw does essentially nothing because of its location, and you just need to drive and keep topping off until it's full. Now, if you really wanted to be fancy and ensure there are no air bubbles, you should... also not bleed the system. You would vacuum the system. That's because no bleed, whether thru a traditional bleed screw, our useless bleed screw, or self bleeding, is perfect. But a vacuum down to as-near-as-can-be absolute vacuum will definitely insure the system is free of bubbles. |
Wolf 3352340.50 |
10-03-2019, 01:35 PM | #7 | |
99
Rep 237
10-03-2019, 03:14 PM | #8 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
You should :
1) crack the bleeder screw when filling the new expansion tank. 2) Close the screw. 3) Put the cap on tight. 4) Put a battery charger on it, set to maintenance. 5) put the key in & turn the your heat all the way up & set to level one. 6) press the gas pedal down for 10 Seconds until you hear the water pump kick on & let it run for 14 min. 7) when it's done, check the level of the expansion tank. If you have to add coolant repeat steps 1-6 & you are done ! You might say it's overkill, but better safe than sorry ! |
10-03-2019, 03:16 PM | #9 |
38
Rep 85
I've got to speak up because the "no bleeding needed" statement is simply wrong, per newtis. If you're new to BMW's you may believe that the system is self bleeding. It is not.
Like the OP's '11 335, these use an electric coolant pump and an electronic bleeding procedure that is started as the expansion tank is being filled. It takes about 12 minutes and forces all the air out of the system. The Pierburg and VDO electronic pumps used in them are expensive ($300+) and all the procedures to bleed the system should be used. Here's the procedure on a typical N52: https://www.newtis.info/tisv2/a/en/e...-drive/ElXYxd2 Newtis has a procedure related to bleed/fill with vacuum filling unit, but still requires the above electronic bleeding as well. The best procedure I've used has a tool like a funnel that screws onto the expansion tank. It allows coolant to be poured in, and forced up out of the tank as bubbles are released, without making a mess. Doesn't require a bleed screw to be opened.
2007 530I, 2007 328xiT
2003 325XI (gone) 2004 530I (gone) 2001 530I (gone) BMW CCA Member 15+ Years Last edited by banglenot; 10-03-2019 at 03:35 PM.. |
Efthreeoh17315.00 |
10-03-2019, 03:44 PM | #10 | |
99
Rep 237
10-03-2019, 04:12 PM | #11 | |
204
Rep 525
The fact that, even according to newtis, the electric pump procedure is done with the "bleed screw" closed makes the system, by definition, self bleeding. That's literally why there are two hoses going to the expansion tank. It isn't rocket science, people. It's the way it's designed. EDIT: about "new" people; it is likely the reverse of your suggestion. DIYers who have been around BMWs for decades have a much higher chance of understanding how BMW designs their cooling systems. At least one could hope. Last edited by ewicky; 10-03-2019 at 04:39 PM.. |
10-03-2019, 05:44 PM | #12 | |
99
Rep 237
Efthreeoh17315.00 |
10-04-2019, 08:58 AM | #13 | |
17315
Rep 18,737
If the system were a true vacuum, the pump would not be able to spin. The cooling system needs air space in it to allow for coolant expansion. The air space is in the coolant reservoir, which is why the tank is at the highest point in the cooling system. Last edited by Efthreeoh; 10-04-2019 at 01:32 PM.. |
10-04-2019, 01:33 PM | #14 | |||||
204
Rep 525
Look, I'm not trying to be a donkey's rear end here. And I recognize several members' names as being terribly helpful all over these forums. Respect is due for that. But to answer this thread's particular question: our cars don't have a traditional cooling system design that would need bleeding. And I feel like people who understand gravity and displacement can see how, because of the way BMW designed it, there's no way the system could possibility be bled out of the bleed screw. |
10-04-2019, 01:54 PM | #15 | |
204
Rep 525
I joke. On a more serious note, you have voiced your opinion and so have I. Anyone reading is hopefully capable of critically thinking and can make their own decision, and not just blindly follow procedures that weren't meant for them, just for the heck of it. |
10-04-2019, 01:56 PM | #16 | |
17315
Rep 18,737
And TBH what automotive cooling system is not self bleeding? All of them are design to bleed off pressure. I and others here that wrench on these cars really just don't understand why you think you have better bleeding technique than the manufacturer who actually designed the system does. |
N52bigblock98.50 |
10-04-2019, 02:23 PM | #17 | |
99
Rep 237
Efthreeoh17315.00 |
10-04-2019, 07:59 PM | #18 | ||
17315
Rep 18,737
But I will argue the bleed screw doesn't need to be on the engine cylinderhead; it needs to be at the highest point in the cooling system, which is where the air will collect when pushed from the block as the liquid coolant displaces the air within the block. So the bleed screw is on the cooling system reservoir, which is higher than the top of the cylinderhead and a few inches above any water jacket inside the head. Not sure you understand what vacuum means in terms of physics. You are completely wrong because you state and argue that the bleed screw is useless and advise not to follow BMW's bleeding procedure. In fact when one reviews BMW's literature regarding the design of the N52 engine and its use of an electric cooling pump, it states BECAUSE the system uses an electric cooling pump "a special filling and bleeding procedure must be implemented for servicing." Pg. 58 of the New Generation 6 Cylinder N52.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
N52bigblock98.50 |
10-05-2019, 04:35 PM | #19 |
2341
Rep 3,539
Just a comment...Every reputable independent bmw shop in my area claims that the system is self bleeding as well. And these are the guys that used to work for bmw before they left and opened their own shops.
10-05-2019, 09:12 PM | #20 | ||
2697
Rep 4,031
There are multiple reports on the forums of reservoirs bursting due to too much coolant in the system with NO room for expansion of the coolant as it warms, and possibly a failed pressure release mechanism. Obviously, if the reservoir failed in such a manner that plastic shrapnel was introduced into the system, care should be taken to make sure that has NOT gotten into the pump. So OLD Reservoir failure may cause pump failure, OR be the symptom of another issue which MAY cause failure of the NEW Reservoir. If OP is replacing the Old Reservoir simply due to a leak, his question MAY be: Is there a way to replace the reservoir, so that I don't have to Bleed the system? The answer is YES. Simply clamp off the larger hose BELOW the reservoir (to prevent coolant from flowing UP, out of the hose fitting when disconnected from the old reservoir), and have the replacement reservoir ready to attach as soon as you remove the old. THAT will prevent loss of more than about an ounce of coolant if done correctly, and if the fitting separates without issue. I'm NOT familiar with the N55 Engine, but if the Reservoir is basically the same as N52 with two fittings, that should work. That said, when you have an electric coolant pump and a battery charger, WHY take any chances that there is an air pocket in the head that, as Neil suggests, may cause local overheating and damage a valve seat or other issue from overheat. BEFORE you start the engine, you can make sure that ALL the air is out by running the bleed procedure, topping off, and running it again. You do NOT have to "babysit" the bleed procedure, so what's the rush? If there is ANY doubt about cooling system history, or how much air got into the system, (1) DRAIN the old coolant, and then (2) Refill & BLEED the system according to this TIS procedure, SPECIFICALLY for N55: https://www.newtis.info/tisv2/a/en/e...check/D84yFYBu QUESTION: On US models which do NOT have a "Water Valve" or "Auxiliary Pump" located at the base of the left Strut Tower, is there any reasons to do Step 3 of the procedure linked above: "Set heater to maximum temperature and turn blower down to lowest speed"? George |
Efthreeoh17315.00 |
10-06-2019, 08:34 AM | #21 | |
17315
Rep 18,737
All cooling systems can trap air inside the cylinderhead, which is problematic, because the head can rapidly overheat without indication from the temperature sensors built into the cooling system. The E9X cooling system using an electric pump eliminates the risk of overheating the head. Why someone comes on here and says BMW's bleed procedure in the TIS is only for professional technicians working in dealership is just stupid. Plus, it's such a simple and easy procedure follow.
10-06-2019, 01:31 PM | #22 | |
99
Rep 237
you fill the system with the bleed screw undone, then tighten the bleed screw, put the cap on, and you ACTIVATE THE COOLANT PUMP. (just like it says in the bleed or venting procedure, strangley) You can quite happily walk away from it and it will bleed the air out of the cooling system, because the pump is circulating the coolant and venting the air into the expansion tank, then you simply top it up afterwards. I worked for BMW as well from 2003 until 2012 in 3 different countries and i have never seen or heard anybody not use the proper bleed procedure, except for an apprentice. He didn't do it once and overheated the car. It's a disaster waiting to happen. As Efthreeoh mentioned the procedure is so damn easy to do anyway. Why the hell wouldn't you? It would be far quicker (in reality less than 5 mins) to do it properly than to fart around waiting for all the bubbles to "hopefully" come out and keep topping it up for god knows how long. I'm done now. Promise! Last edited by N52bigblock; 10-06-2019 at 02:04 PM.. |
