Windshield washer fluid leak?
10-01-2019, 03:13 PM | #1 |
8
Rep 104
Trying to figure out where this leak could be coming from, seems like it's. My washer fluid since it's green but not sure. Anybody have this type of issue?
10-01-2019, 03:14 PM | #2 |
8
Rep 104
10-01-2019, 03:34 PM | #3 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
If its your washer fluid it'll be coming from the passenger side fender off the end of the rocker panel, if you have headlight washers there's also a possibility it'll be coming from one of the sides of the front bumper. There's multiple ways washer fluid can leak
Common sense is a flower that does not bloom in everyone's garden
10-02-2019, 12:18 AM | #5 |
21
Rep 44
The washer fluid lines connect to the tank through removable filters with rubber gaskets that can leak. The filters are cheap and changing them is relatively easy. I had 3 filters for the lines to the windshield washers, rear window washer, and headlight washer. Non-wagons will have two and cars without headlight washers will just have one. The fluid will all spill out when you remove the filters so have new fluid on hand.
On the color: OEM BMW washer fluid and coolant are both blue, although either could be green if aftermarket. |
10-04-2019, 07:29 AM | #6 |
78
Rep 239
I've had washer fluid leaks 3 times, all different pieces - the main pump in the reservoir and each of the headlight washer nozzles. The pumps are pretty cheap for aftermarket - I got a Febi from FCP Euro and it's been fine for several years. There is a second pump for the headlight washers and probably a third for the rear window on wagons. No aftermarket available for the headlight washer nozzles and they're around $100 each. Good videos on YouTube on how to replace all of these.
10-04-2019, 07:51 AM | #7 | |
Rep 2
10-04-2019, 05:24 PM | #9 |
202
Rep 449
the only leak I've had is from the little washer pump that is easy to replace. There is a little rubber seal inside the pump that the motor shaft has to pass through to drive the pump...it wears and allows fluid past into the electric motor and out ...usually down the side skirt to in front of the back tire.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C |
10-05-2019, 08:33 AM | #11 |
50
Rep 232
Drives: 2009 328i sedan
Here is a YouTube video that may help. He fixes the leak with JB Weld.
10-05-2019, 01:39 PM | #12 | |
78
Rep 239
