Explain door mirror options, please
09-29-2019, 03:35 PM | #1 |
8
Rep 86
Can anyone explain to me how do the various mirror options on E92 work? I have a 2011 335is, which came pretty much fully loaded as standard. I have options:
S430A Interior outside mirror with auto dip S431A Interior mirror with automatic dip S459A Seat adjuster electric with memory Plus, there is a note on realoem somewhere, that "Special option SA 430 contains SA 313" S313A is "Fold-in outside mirror". I need to buy both door mirrors (both were damaged and previous owner replaced them with pre-lci mirrors). I understand I should be looking for 3-pin ones, with auto-dimming and folding options, but I have some doubts: - are all 3-pin mirrors electrically folding? - are all auto-dimming mirrors also electrically folding? - my car actually has 5 wires going into the plug? Why? Are two of them unused? - if the mirror is electrically folding but not auto-dimming, can the glass be simply replaced and connected to get a fully optioned mirror? I tried solving that through realoem, but it's traditionally very confusing when it comes to mirrors. I'm seeing multiple part numbers with seemingly same options, see for yourself: https://www.realoem.com/bmw/enUS/sho...diagId=51_7659 https://www.realoem.com/bmw/enUS/sho...diagId=51_7661 Can anyone help? Last edited by GTwice; 09-30-2019 at 12:35 AM.. |
10-02-2019, 12:56 AM | #2 |
456
Rep 2,749
1. no
2. yes, except m3 3. may be you car had door replaced and they are with wiring from 5-pin mirror donor car 4. no what connector in mirror side you have right now ?
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
10-28-2019, 02:21 AM | #3 |
8
Rep 86
Problem solved - I bought a pair of 3-pin, power folding and dimming mirrors, plugged them and everything works.
But, for the mystery of 5-cables going into my plug - I checked the passenger side, and there are only 3. There is a chance you are right, ptpending - seems like this part of the wiring (between window/mirror switch and mirror) is from 5-pin car. But why? No idea, no record of the door being replaced or damaged, but who knows. |
02-13-2021, 02:18 PM | #4 | |
Rep 1
