Is this Belt Tensioner bad?
09-24-2019, 03:04 PM | #1 |
34
Rep 184
I was looking at engine bay more closely today and see this belt tensioner pulley looking possibly crooked and belt looking like it's partially off, getting dangerously close to that big metal ring below it.
What do you guys think? Can just the pulley be replaced or more like entire belt tensioner? At least belt looks like zero cracks.
Current: 2017 F30 330e PHEV
Past: 2007 BMW E93 N53 Convertible |
09-24-2019, 03:16 PM | #2 |
108
Rep 148
Replace the tensioner, bolt that holds the tensioner and your belt. The pulley and the tensioner come together as a unit. Cost you around $100 in parts. This is an easy diy.
09-24-2019, 03:37 PM | #3 | |
34
Rep 184
I'll get Febi tensioner and as for belt, will this be fine: 6PK1830 CONTITECH (RealOem tells me to get 6PK1827) I notice OEM BMW is also Contitech but it is 1827mm while anything on the market is 1830mm... 3mm difference. Wondering if they did this so more people would go buy expensive belt with BMW logo on it?
09-24-2019, 03:44 PM | #4 |
1911
Rep 13,104
Could you put up and after change picture?
Looks like I can kind of see it biased toward the outside and little fraying in the same spot. Ozwerks makes a belt fail shield now. for all models broken belt https://www.e90post.com/forums/showthread.php?t=1305990 http://www.bimmerfest.com/forums/sho....php?t=1231881 http://www.e90post.com/forums/showpo...3&postcount=23 http://www.e90post.com/forums/showthread.php?t=1477111 https://www.oxwerkzperformance.com/and they are mostly out of stock. Last edited by ctuna; 09-24-2019 at 04:27 PM.. |
schriss33.50 |
09-25-2019, 03:40 AM | #7 | |
34
Rep 184
I have seen the belt shield thingy, but nowhere it says to be compatible with N53. I would assume it is, but doesn't say so. Nice thing to have, weird it's not mass produced cheaply as just a piece of metal.
09-25-2019, 06:20 AM | #9 |
34
Rep 184
Scary to think I was on a highway going like a rocket for 1 hour trying desulphate, just 1 week before I noticed this.
09-29-2019, 02:13 AM | #10 |
34
Rep 184
Took old one off, shiny part on the pulley is where the belt was touching it.
09-29-2019, 06:31 AM | #11 |
17315
Rep 18,737
I'm sure it wasn't intentional, but neat photo.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
10-06-2019, 02:23 PM | #12 |
34
Rep 184
New belt tensioner is on. Also, the belt was original BMW, seems like it was the original, never changed. Brand new contitech is on.
StradaRedlands4941.50 |
12-10-2022, 05:22 PM | #13 |
1082
Rep 1,676
Had a belt walked 1/3 off the pulley problem this weekend. Turned out to be a failing mounting bolt. The AL9 aluminum bolt was not strong enough. Makes me wonder how much of the problem was the bolt failing and not the assembly's fault.
My post here: https://www.e90post.com/forums/showthread.php?t=1976331 And pics: Failing bolt on top, against a new bolt below: |
12-10-2022, 09:52 PM | #14 |
17
Rep 31
I wonder if that bolt was reused from a previous tensioner replacement. Those bolts need to be changed once they are torqued down to the proper torque. At any rate, good thing you caught it before it failed!
12-10-2022, 10:38 PM | #15 |
1082
Rep 1,676
Yeah, if this engine ate the serpentine belt I will just dump it for an Audi anyway.
This failed bolt was a new one that came with the INA tensioner, so it was used only once and torqued-angled to spec (18 lb/ft+90deg). Maybe the supplied bolt is of defective metallurgy. Anyway the newest bolt that went in today is a Rein. I used 17lb/ft+80deg this time. LOL. Time will tell. |
12-11-2022, 06:26 AM | #16 | ||
1006
Rep 2,243
Drives: 2007 328i / 2014 M235i
I usually put a very very small amount of grease on these aluminum bolts so they don't gall the threads and I then use a slightly lower torque |
12-11-2022, 11:34 AM | #17 |
4942
Rep 3,000
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
I really hate aluminum stretch to yield bolts. They always make me cringe when I'm doing the extra 90 or 180 on them...
12-11-2022, 11:40 AM | #18 | ||
1006
Rep 2,243
Agree I think they are on the edge of stripping hence why I reduce the torque |
12-11-2022, 12:50 PM | #19 |
1082
Rep 1,676
I did not use any lube or motor oil on the threads. But given the number of so-called "tensioner failures", I wonder how many of those were actually bolt failures.
Wish I kept the original tensioner, because I did not see anything wrong with it when compared to the new one. But I just changed it anyway. These tensioner bolts are not the only problems, engine mount bracket bolts (4 on each side) are known to snap (Rein sells a set of bolts to address those). And cylinder head bolts too. It may just be BMW's poor choice of bolt sizes and metallurgy. This engine was the first to use the stupid magnesium composite casting that saved 22 lbs. And maybe the last? LOL Magnesium weakened the block that N54 did not use it. And engines with turbos is the way manufacturers are moving. Hopefully this magnesium joke is the last from any manufacturer. But in the mean time, yes reduced torque just a bit. |
