2010 2011 BMW 5 Series Forum F10 AutoTalent | Dinan Exhaust+Intercooler+Engine Software for Bmw 550i 2010-2013 |
09-24-2019, 01:24 PM | #1 |
2311
Rep 12,654
Dinan Performance Engine Software Upgrade To order stage 1 please visit our website by clicking HERE To order stage 2 kit please visit our website by clicking HERE To order stage 2 diy please visit our website by clicking HERE To order stage 3 please visit our website by clicking HERE To order stage 4 please visit our website by clicking HERE To order stage 5 please visit our website by clicking HERE After many hours of further research, tuning and testing Dinan have improved on their hugely popular Stage 1 Performance Software. Their team was able to make Stage 2 much faster by improving turbo response across the power-band. This tuning is especially noticeable in the first two gears, now catapulting the car off the line. Tuned for a smooth power-band to put down predictable and even power in all gears and throttle positions. This smoothness improves the quality of the shifting and the overall drivability. With Dinan’s software, your 650i will be capable of achieving its natural top speed as the governor has been removed. Dinan matches the new car warranty coverage for up to 4 years or 50,000 miles, including the possibility of consequential damages. No one offers better performance or backs it up with such comprehensive warranty coverage. ---------------------------------------------------- CHR Wheel Set To order titanium wheel set please visit our website by clicking HERE To order silver wheel set please visit our website by clicking HERE Dinan has used its extensive knowledge of BMW wheel fitment to use the BBS CH-R product line to its fullest. The physical dimensions of different tire manufacturer's products may vary for a given tire size. In some cases minor trimming of the fender well lip may be required due to vehicle production tolerance variations. BBS Wheel Set Highlights One Piece Counter Pressure Cast Wheel Back-milled spoke area Spun inner rim using BBS Flow Forming Process Featuring stainless steel rim protector Weight optimized by FEM analysis DINAN center cap included ---------------------------------------------------- TPMS Sensors To order tpms sensors kit please visit our website by clicking HERE To order tpms sensors please visit our website by clicking HERE Supplying the OEM BMW part number that is pulled from the existing wheel/tires is the ONLY way to ensure that the proper replacement TPMS sensors are selected. ---------------------------------------------------- Dinan Free Flow Exhaust To order exhaust with polished tips please visit our website by clicking HERE To order exhaust with black tips please visit our website by clicking HERE Dinan's Free Flow Exhaust improves exhaust flow by reducing back pressure, resulting in increased power output and a great sporty sound that is civilized when you want it to be and pleasantly aggressive under harder acceleration with zero drone. 100% stainless steel construction and exacting specifications ensure that the system fits correctly using the factory hangers and will resist corrosion for years to come. The design reduces overall weight as well and features 3.5'' polished tips for a tasteful high performance look. Features + Sportier sound + 100% 304 stainless steel construction + Bolt-on installation + Four 3.5” stainless steel polished & laser engraved exhaust tips + Add 10 Horsepower when used in conjunction with the Dinan Performance Software Upgrade ---------------------------------------------------- Dinan High-Performance Air-to-water Intercoolers To order air water intercoolers please visit our website by clicking HERE To order air water intercoolers 1 please visit our website by clicking HERE More power, great looks, more consistent performance, and no downside by upgrading to the Dinan High-Performance Intercoolers for the N63TU V8. Heat is the enemy of horsepower, beat it by replacing the air-to-water intercoolers with larger units from Dinan to reduce the charge air temperature. The two intercoolers are beautiful and purposeful looking, wrapped in black powder coat and laser engraved with the Dinan logo. Features Replaces factory air-to-water intercoolers with 23% larger units. Black powder coated and laser engraved intercoolers. Includes silicone hoses, coolant lines, mounting brackets and hardware ----------------------------------------------------- Dinan Performance Spring Set To order please visit our website by clicking HERE Dinan's Performance Spring set for the F10 550i provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan lowers the vehicle by a 1/2" in front and 1/2" in the rear for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car. The increase in stiffness of the springs will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs will also provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at low speeds up to the top speed of the vehicle. ----------------------------------------------------- Dinan Control Arms To order rear control arms please visit our website by clicking HERE To order negative camber control arms please visit our website by clicking HERE Negative Camber Control Arms provide a remarkable reduction of understeer and more immediate turn-in by inducing more negative camber on the front wheels. The additional negative camber improves the grip of the front tires in the turns thus reducing the vehicle's tendency to "plow" or "push" the front end for those who drive a bit more aggressively. This increase in negative camber is accomplished in two ways. The shorter front upper control arm increases camber gain, which is the amount of negative camber that is created by the geometry of the suspension as the car rolls to one side. In addition the static negative camber or the amount you will see on your alignment read out is also increased. The combination of static and dynamic camber gain adds an increase in front grip when the tire is loaded. Features + Replaces front upper control arms with ones that increase negative camber by -0.5° + Improves grip of front tires + Evens out tire wear during aggressive cornering How to Place Your Order: Phone Domestic: (855) 973-2757 X 104 Phone International: (310) 231-7800 X 104 E-mail: online@autotalent.com Website: www.AutoTalent.com Payment: Installations: Feel free to visit us at our facility in Los Angeles, CA. We install everything we sell. 19143 S. Hamilton Ave Gardena, CA 90248 Shipping: All orders are shipped via FedEx, UPS, USPS and Pilot. International, Hawaii and Alaska customers: Please contact us for the best quote possible. Hours of Operation: Monday through Friday: 10AM-7PM Pacific Time Saturday: By appointment only Last edited by AutoTalent; 09-26-2019 at 03:05 PM.. |
