Blow Off Valve question
09-21-2019, 09:49 PM | #1 |
113
Rep 513
Drives: 2008 335i
Hi Folks.
I just put a heavier spring in my blow-off valve and now it makes a subtle pawph sound instead of a higher PFFFFTT. I did notice at higher bost that I still get the PFFFFTT, but it's accompanied by the pawph sound. I'm running JB4 Map 5 so like 16 psi. Also, I put the heavier spring in as when I was building boost I constantly hear a ppssshhfff sound, like something was leaking. I have no boost leak engine codes, ATM Thanks for any advice you can give. |
09-22-2019, 09:13 AM | #2 |
352
Rep 2,050
Log a 3rd gear pull and see if your hitting boost target
'10 e92 N54
DCI intakes, ER chargepipe, TIAL BOV, VRSF 5in FMIC, BMS Downpipes COBB e30 |
09-22-2019, 11:52 AM | #3 | |
2001
Rep 3,731
09-22-2019, 10:16 PM | #4 |
113
Rep 513
Drives: 2008 335i
I went from sub stock psi levels due to having a boost leak to new stock turbos now running 16 or so psi
09-22-2019, 10:18 PM | #5 |
113
Rep 513
Drives: 2008 335i
09-22-2019, 10:20 PM | #6 |
113
Rep 513
Drives: 2008 335i
Will the lighter spring loose boost once psi is too high?
