Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Can I run with no TPMS at the track?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      09-21-2019, 01:23 PM   #1
BryanH
Drives: 2011 328i Sedan (6MT), MR2T
2011 328i sedan with Sport package. TPMS system is working and happy. My searches haven't yielded an answer to this question:
If I go to an autocross and change to wheels with no TPMS sensors, and I have my TPMS-equipped wheels in the paddock area that I return to from time to time, will the car allow me to drive at the limit for the entire day? Or might it force some level of traction control or stability control on?
Thanks!
      09-22-2019, 11:14 AM   #2
weehe126
1161
Drives: 2017 340i
You will just get a tpms warning light.
Tim603482.50
      09-25-2019, 01:53 PM   #3
BryanH
Thank you!
      10-10-2019, 06:16 PM   #4
PS2N54
79
Drives: 335i
on my 2008 328xi with sport package, there is no TPMS inside the rims. I just did a rim swap yesterday. the car does alert when tire pressure is low/high
      10-13-2019, 08:56 AM   #5
langsbr
234
Drives: 335i
You could disable tpms and enable abs sensor based ftm (flat tire monitor) like European models have. That's what I did. It makes tpms battery issues a thing of the past as well. The only reason US has tpms is because of arbitrary regulation that says it must measure pressure and not just tell you if one is low.
