Nightmare E92 :(
09-21-2019, 06:04 AM | #1 |
Rep 17
Nightmare E92 :(
Hey guys
I'm lost a little, I'm hoping you guys can shine some light in the right direction.... I was driving down the road on a beautiful night music on blast enjoying some back roads, when all of a sudden the vehicle started to kind over heat and it went in limp mode and then finally it turned off.. So I said to my self shit the engine seized; Tried starting it it wouldn't do anything at all. Towed it home, next morning i spin the engine by hand it moves freely so phew is not the engine but the problem still lies of why it doesn't start so i say to myself in a twisted world what if the heat took out the starter, and it did I took the started out bench tested it and nothing happened, so I said Hurray is the starter... bought a new one, Bench tested it it worked fine before I put it in; Put everything back together and nope Still nothing... so I'm like ok Let me replace the battery, nope nothing... Then I said ok Let me bypass the IBS... nope nothing.. So i take everything apart again! and give power to the starter starter works fine, but I went to test the Single plug that goes to the starter and it has no power... so I said ok fuses, WEnt underneath the glovebox and tested all the fuses all fuses are good..... Then I'm like okay let me see if the car is just not recognizing that is in park but I tried putting it in neutro and for some weird reason its stuck in park and it doesn't want to move... Where can i go to from here |
09-21-2019, 08:51 AM | #4 |
3537
Rep 3,049
There were no dash lights, CiC displays or was the music too loud? It sounds like a potential water pump issue but you kept driving? When mine went out, I pulled over, let it cool down and limped it the short distance home.
09-21-2019, 09:01 AM | #7 |
Rep 17
Even if it was the water pump should still be able to start; theres no power going to the starter.
09-21-2019, 09:50 AM | #8 |
3537
Rep 3,049
Unless you did further damage by continuing the drive it. There is no telling what happened until you investigate further and I'd start with reading codes.
09-21-2019, 10:29 AM | #10 |
456
Rep 2,749
there is problem with wires from battery to engine compartment, they are routed via hole in battery compartment to outside and usually oxidise, become weak and break, sometime with fire
to check these outside connectors you need to remove rear right wheel, arch cover and you'll see them this problem usually for cars in areas with snow, rain and high moisture like NY
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
09-21-2019, 11:40 AM | #11 | |
2697
Rep 4,031
Just the Facts ;-)
Before anyone on this forum can offer any meaningful advice other than the above, we need to have answers to the following QUESTIONS: 1) What warning lights appeared on the Instrument Cluster BEFORE the engine died? 2) When you tried to restart it, what lights appeared on the Instrument Cluster? 3) What sounds did you hear when you pressed the START button, and where did any sound come from? 4) Other than START activation, what else does NOT work in the car, such as Central Locking System, Entry Lights, Radio, Windows, Climate Control Panel, Blower functions, etc.? 5) Do you have a DMM (Digital Multimeter) and know how to use it? (We can suggest a $6 HFT (Harbor Freight Tools) unit that has downloadable instructions for use, and in LESS than an hour, you can do simple voltage tests to diagnose the issue. 6) Do you have a Scan Tool of any type? 7) Do you have a computer or other device that can connect to the Web & read information about your car, such as the following TIS circuit diagram showing Starter Activation by the CAS? Here is a link to TIS circuit diagram for 2008 E92 328xi Starter (M6510a), showing activation via Black wire from Pin #22 of Connector X13376 at the CAS. Note that wire goes from the CAS to the E-box under the hood where it passes through Connectors X6011 & X60531: https://www.newtis.info/tisv2/a/en/e...system/uXuCNh9 Here is the location of Connector X6011 in the E-box: https://www.newtis.info/tisv2/a/en/e...xi-cou/SL92ADs In summary, you appear to have several issues, one of which may be related to another. (1) Your "No-Start" issue is electrical or electronic in nature (NO activation of the Starter Solenoid by the CAS Module via the wiring identified above, and as you tested(?). However, you have another issue which caused the engine to shutdown after "UNspecified" warning lights or driving issues. That shutdown could have been caused by a number of things from Coolant Pump Failure to Alternator Overvoltage (which causes issues with Control Module performance & communication). Your next step should be getting the least-expensive way of reading ALL Fault Codes saved in your DME (Engine Control Module) and ALL Freeze Frame Data or Details related to those codes. That Freeze Frame Data is as or MORE important than the codes themselves as it indicates conditions existing at the time the code was saved, such as SYSTEM VOLTAGE, ECTS Temp Signal, as well as mileage/km at the time the code was saved, so you can determine what faults occurred when, and whether an earlier fault led to a later fault or was unrelated. Your car is smarter than most of us, 'cuz it was designed by people who knew what they were doing. We need to understand how the car is designed, and what information it retains when something malfunctions. If that is NOT your thing, then get it towed to a shop who knows how to do that. George |
09-21-2019, 12:25 PM | #12 | |
Rep 17
ISTA says no communication to starter; I replaced the CAS RElay when I turn on the vehicle all lights come on, as normal and also I do hear the chime. see link below When the vehicle over heated it over heated to up to 245 degrees and then it turned off showing just the temperature light being red. |
09-21-2019, 04:05 PM | #13 | |
2697
Rep 4,031
George |
09-21-2019, 04:08 PM | #14 | |
Rep 17
