Reverse lights out. Any inputs?
09-19-2019, 07:41 PM | #1 |
22
Rep 178
Hey guys,
Been sifting through some issues with my E90. After a bunch of retrofits, coding and maintenance. Its finally time i fix my god damn rear lights What ive done so far: checked CC-ID and its throwing ID 115 and 117 (Left and right rev light) scanned with inpa and i get the relevant codes 9CC3 and 9CC4 checked the FRM modules short circuit monitor with TOOL32 and they all report 0 (did try to reset them aswell but nothing changed) I inspected the lamps along with lamp holders and verified they light up with external PSU. Am i just beeing plain stupid here and overlooking the simplest thing? i can not get them back on, I suspect a wire has corroded or an open loop since both left and right went out at the same time. Winter is coming fast here in norway and reversing without any lights is not fun :S Any input is appreciated
2006 E90 Titan Silver 320D |M sport|Custom|RGB AE| Eibach Pro coils|Spacers|Blue Shadow/alcant|Custom Black F10 taillights|Hifi|Dipped Roof|GlowShift Guages|M sport Splitters|Superchips Tune|
09-19-2019, 11:32 PM | #2 | |
2697
Rep 4,031
https://www.newtis.info/tisv2/a/en/e...lights/hw11Pwd Please let us know what you find, George |
Hybridz0rz22.00 |
09-22-2019, 08:41 PM | #3 |
78
Rep 239
Check the trunk wiring in the boot from the body to the trunk. Wires commonly break there. There's an aftermarket replacement harness if you want the most durable fix or you can reconnect the individual broken wires for the cheapest fix.
Hybridz0rz22.00 |
10-22-2019, 04:15 AM | #4 |
Rep 1
Right Lights
BMW E90 facelift: Any idea if the following are connected as they suddenly stop working all together:
reversing light right failure fog light front right failure fog light rear right failure |
10-28-2019, 11:45 PM | #7 |
22
Rep 178
Update. After some probing around and checking wires. It turned out to be a bunch of things. The thing that made me suspect it not beeing the bulbs was both going out at the same time. I found about 5 bad wires in the rubber cable loom connecting the boot to the car. after soldering in new wires the lights still didnt work.. After checking the bulbs they looked fine. But did not messure anything aka open loop. So after replacing them aswell. we got lights working
