Need some help with SOS failure, no audio
09-18-2019, 09:18 PM | #1 |
113
Rep 176
So I know this is a pretty common issue with pretty much all BMW's, but I have the SOS warning light and no audio from the radio or seat belt chimes/door chimes. I've ordered the loop jumper (PN 61136917541). I unplugged each device in the trunk to see that they all have the slow flashing red light, up until I get to the MOST connection behind a small cover in the driver footwell, I have no red light here, indicating that It was the last module being the SAT module which seems to be a common issue. I tried using the jumper cable but still no luck, absolutely the same. I checked what I thought were the fuses but I could be mistaken. The HU still works but it doesn't do anything when you turn it up and SAT isn't an option anymore. All of this did happen after some light NCS expert coding but I didn't think they were related. Any help would be greatly appreciated.
2020 BMW 530i M Sport
2015 BMW 740Li M Sport 2016 BMW 328d M Sport |
09-19-2019, 02:55 PM | #2 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
09-20-2019, 09:15 AM | #3 | ||
113
Rep 176
09-20-2019, 10:15 AM | #5 |
113
Rep 176
I only get the SOS failure on the dash, I just don't have any audio which is driving me insane, no door dings or warning dings either. I don't need satellite radio or seat belt chimes and I'll never use the SOS function. I just want the logic 7 back.
09-20-2019, 06:32 PM | #6 | |||
1903
Rep 6,968
09-20-2019, 10:45 PM | #8 |
Rep 2
Drives: 2013 335i (Current)
I got this very randomly for the first time today and it hasnt gone away
09-21-2019, 10:35 AM | #9 | ||||
113
Rep 176
09-21-2019, 11:20 AM | #10 |
1911
Rep 13,104
Basically all Most units are in the Trunk area there is a most test
point under the dash. (on the under dash board drivers panel in most US Cars I heard they moved it to the glove on some) There is a picture of this panel and the Most Hub in the link supplied below. The Most Bus is a Serial line any break in it and nothing in it works. Fiberoptic lines can be checked/traced by shinning a light source in one end and seeing it come out the other. Most test point http://www.e90post.com/forums/showthread.php?t=347222 Last edited by ctuna; 09-21-2019 at 11:26 AM.. |
09-21-2019, 11:23 AM | #11 | |
113
Rep 176
09-21-2019, 11:45 AM | #12 |
1911
Rep 13,104
Ista is more help with this kind of problem.
Inpa might show a module being down but it's not as good with most bus issues. Actually Most Bus issues are kind of hard because one module takes the whole bus down . Try running functional jobs in Inpa to see if it talks to the modules. See first link. diagnostic manual ista/inpa https://bimmerprofs.com/diagnostics-inpa-part-1/ https://www.google.com/url?sa=t&rct=...xo19teM9vkTF-C https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF https://www.bimmerforums.com/forum/s...-P-actually-do Assuming the audio system is stock. The logical sequence would be . Is there at least one light coming out of the Head unit and going to the Most Test Point. Does that Light make it to the most Hub. Is there a break or bad module in one of the devices in the Trunk area. Which may include Sat module , TCU , TCU Mulf pair (two stacked modules each with a Most line ) , Combox , Mulf 2 only, dAB in the UK, HD module in early cars. Logic 7 amp If you have Logic 7 did you read the LED indicators on the amp as described in . http://www.bmwlogicseven.com/?p=3837 This amplifier has a diagnostic LED, which will show lots of things you most likely don't know about. Here you can see where it is located. So look at that LED, turn on the radio and look at it: More in that thread. Last edited by ctuna; 09-21-2019 at 11:57 AM.. |
09-21-2019, 12:36 PM | #13 |
113
Rep 176
UPDATE: After literally checking every single fuse on the card (None of which were blown...) I tried one more time and suddenly its back to normal? So I'm assuming what happened was a fuse was a little loose
I really really appreciate the help I receive on this forum, everyone knows that if I would've taken the stealership, it would've been a week and $200 to tell me something is not working. Big thanks to ctuna for the enormous insight on MOST issues, hopefully this will help someone in the future gets their audio back
09-21-2019, 02:25 PM | #14 |
1911
Rep 13,104
If you have been working on the car for awhile there is a good
chance you depleted the battery . I would check it an put it on a battery tender or charger for a long slow charge. Best to get the Inpa (standard tools) and Ista d going if you don't want to be subject to that wait and diag charge and if you want to do any Diy ing. |
