BMW X5
      09-18-2019, 03:14 PM   #1
StrykerRan
StrykerRan's Avatar
15
Drives: BMW X5 40i
Uniden R7 Radar install with Mirror Tap
Hi- just had my Uniden R7 installed with a Mirror Tap (first time). I wasn't comfortable separating the mirror cover so I went to a local stereo shop to have it installed for $50. As you can see from the pics, the tabs are quite brittle so be very careful using a simple pry tool to separate the seam.
I used the "second from the smallest" tap size. So others can save some money and buy that exact size. I recommend getting the 15" (I got the 10") so you can route the cable easier, say to a blendmount underneath the rear mirror. Any slack can easily fit inside the mirror cover.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Follow the install instruction of Mirror Tap and remember to ziptie the cable to the X5 wiring harness so that it is intact and won't tug on the mini taps if the radar was to fall down.
This BMW, 2019 X5 4.0 seems to retain power in the mirror as well as the cigarette lighter socket for about 5 mins. So after 5 mins, everything will shut off. I have my dashcam and Amazon Auto Echo plugged into the cig.
Total install time 20 minutes which includes 5 mins for the unit to shut down after locking the vehicle.
Hope this helps potential owners of this vehicle.
Appreciate 6
radmjk240.50
DNGRTOM122.50
Cooltones241.00
ladra17.50
Blekp16.00
      09-18-2019, 04:20 PM   #2
scottjays
Starfleet Command
scottjays's Avatar
315
Drives: 2020 X5 M50i
This is great info! thanks for sharing. I plan on using my current blendmount from my F15...hoping it fits my G05 M50i on order.
2020 X5 M50i Phytonic Blue w/ Black Merino
22" 747M wheels,
      09-18-2019, 04:28 PM   #3
StrykerRan
StrykerRan's Avatar
15
Drives: BMW X5 40i
Thanks.
Please share pics when you're done. Blendmound is looking for $139 for the R7 to work with the X5.
      10-24-2019, 11:20 AM   #4
x5randy
x5randy's Avatar
Drives: 2019 X5 40i
How do you like the R7?
Looking for a new RD and I'm almost ready to give on waiting for the V1. I know only 2 more weeks since April that is.
Anyway, do you have gesture control? If so do you have any issues or is the R7 high enough to miss that interference?
What about BSM alerts?
Finally, have you considered installing the remote mute button?
Thanks
      10-25-2019, 11:52 AM   #5
Thumbs
Drives: '01 X5 3.0 5-spd, '10 X6 i35,
<Edited> After reading other posts I understand it a bit more, the theory is that reflected light from the various in-car cameras is causing the laser false alerts.
http://bestride.com/wp-content/uploa...bmw-my-pic.jpg
      12-11-2019, 03:46 PM   #6
jrlv2av8
9
Drives: 2017 M4
2020 G05 X5 & R3 Mirror tap
Pretty much same as above, same wires worked, $43 combo mirror mount and cord worked fine, large leads worked best in mirror plug/harness.
Appreciate 6
emargul204.50
DNGRTOM122.50
radmjk240.50
ladra17.50
      12-29-2019, 09:15 AM   #7
emargul
emargul's Avatar
Drives: M3
Thanks so much your pics were a huge help.
      12-29-2019, 07:32 PM   #8
mir604
Drives: 2012 X5 35D
Do you mind posting a picture of the backside of your mirror mount when its installed. Just want to see how it wraps around the mirror from the backside. I am doing an install on an e70 35D and want to ensure that this bracket will work with my car as well. Can you also DM me the link to the bracket you purchased. I want to make sure the one I purchased is the same one. Thanks
      02-01-2020, 12:13 PM   #9
radmjk
radmjk's Avatar
241
Drives: 2024 X5 M60i, 2020 RRS SE, 201
I just noticed this is a different cover than I have, maybe because of driver assistance? Can anyone confirm that the cover can be removed similarly? Thanks [IMG][/IMG]
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic
2020 Range Rover Sport SE White
2017 BMW 530i xDrive Black
2005 BMW Z4 2.5i Jet Black
      11-02-2020, 09:36 PM   #10
tturgut
Drives: BMW X5 50i M Sport
cost? who can do it?
Hi, how difficult is it to do this?
I guess all you need is a radar detector and the connections from amazon.
1) Local stereo shops to install?
2) total cost?
3) gesture control? (Not really necessary , I can turn it off. but are there any other interferences or is this the only one?
thanks!
      04-22-2021, 06:09 PM   #11
Therealmatzaman
51
Drives: X5 G05
Cover removal for DAP?
Did you ever figure out how to remove the larger cover?
      04-25-2021, 09:04 AM   #12
radmjk
radmjk's Avatar
241
Yes, look back on this thread for your answer. Good luck!
RADMJK
xbimmers
