09-18-2019, 01:08 PM | #1 |
Rep 31
First time changing my brake pads and rotors, will it be hard?
Hi guys, as you may know I had a regular and oil filter and plug service that costed me 1000 over the 777 labour and they suggest i need to change my rotors and pads for my 2015 428i for another 1k. So i decided to do it my self, but im new and im not that confident in ordering the parts, are these compatible or a good combination? Let me know. i was hoping you guys can help me.
Rotors: https://www.ecstuning.com/b-zimmerma...16792227ktzkt/ Pads: https://www.ecstuning.com/b-hawk-par...hb749z.648~hk/ https://www.ecstuning.com/b-brembo-p...206873094~brm/ Last edited by Evangoz; 09-18-2019 at 02:05 PM.. |
09-19-2019, 09:20 AM | #2 | |
1307
Rep 1,827
https://www.turnermotorsport.com/t-b...ke-Differences Also, cross-shop with FCP Euro. They tend to be a little cheaper for OE/OEM parts, plus they have a lifetime warranty. I'm in the South Bay Area as well. Hit me up if you're unsure about the install or if you have any other questions. And just a word of advice, avoid dealerships for basic maintenance in the future. I've done pretty much all my own maintenance for the last 2 years or so and have amassed a decent number of tools to do pretty much anything I need. In addition to this forum, YouTube, and Google searches, this has also been a valuable resource for working on my own car: https://www.newtis.info/tisv2/a/en/
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
09-19-2019, 10:17 AM | #3 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
Not hard. I taught my non mechanically inclined wife how to do it. Get a harbor freight or similar inexpensive c clamp.
For floating calipers: Break loose lugs, jack up car remove wheel. Open hood and remove brake fluid cap. and use clamp to compress the pistons. I usually do it before I loosen the calipers, but if you are unsure on clamp placement or have rigid mounted calipers, , remove caliper from the mount and press on the old pad with clamp to compress. Install New pads. If not changing rotors reassemble. If installing new pads and rotors, next remove the caliper mounts, usually two large bolts. If the rotor locating/securing screw can’t be turned easily with a screwdriver or appears corroded, Get a cheap propane torch from Walmart harbor freight etc. heat up the area surrounding the screw and quench with ice or your favorite penetrating spray a few times. if this doesn’t work, you can drill the head off it. Once the head is off the actual screw part the tension is released and they will turn quite easily. Reassemble. Tip. If using coated rotors like zimmermans, I put the old pads back in and CAREFULLY drive slowly around the neighborhood until they have worn thru the coating to metal. Then I do the pad change. So I basically do the job backwards. Also pelican parts usually has photographic step by step diy for bmw. I know I still refer to them to this day when needed and I’ve been doing this for 25 years. |
09-19-2019, 10:22 AM | #4 |
Great Teacher
1088
Rep 1,305
https://www.pelicanparts.com/techart...W_F30_Tech.htm
They don’t have one yet, but look for any other similar model, e90, f10 just to get an idea of the job. If you like videos instead. https://f30.bimmerpost.com/forums/sh....php?t=1613966 Last edited by Onizukachan; 09-19-2019 at 11:13 AM.. |
09-22-2019, 09:41 AM | #5 |
Rep 31
Super easy!
After dealing with the head ache of figuring out what rotors I have since I have the blue m sport calipers I ended up getting cross drilled and slotted all the way around from Rockauto for an amazing price! Got hella-pagid 2 piece rotors at less then half the price of OE |
09-24-2019, 08:52 AM | #7 | |
15
Rep 230
Brake fluid is very corrosive to paint - just an FYI in case something happens. You can buy the jack pads pretty cheap so you can use a trolley jack. Chock the wheels and apply the handbrake. Otherwise easy. And my local quality brake/tyre shop will do it for USD $75 per axle so despite wanting to do it myself, I don't bother. |
09-30-2019, 06:34 PM | #9 |
Rep 27
Brake Parts
I'll add a plug for RockAuto.com for parts. Good selection and very low prices. Fast delivery as well.
Brakes are easy and a good way to save significant money. Note, the pad wear sensor wire runs to a junction box under the wheel well cover at the edge of the trunk in the rear. There is only one sensor wire for each axle. |
10-01-2019, 10:16 AM | #10 |
Modder of everything I own
147
Rep 491
Make sure you wipe down the rotors to remove the oil on them before you mount them so you don't contaminate your new pads.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
10-07-2019, 02:12 AM | #11 | |
Rep 31
10-07-2019, 02:15 AM | #12 | |
Rep 31
Woah, is it alright if i use the new pads to scape off Zimmerman's coating? Or is it a bad idea since im gonna replace both pads and rotors at the same time |
10-07-2019, 02:17 AM | #13 | |
Rep 31
Okay gotchu guys, I heard alot of jacks failing mid process and that'll be a big problem. Ill keep that in mind |
