Symptoms of failing oil level sensor?
09-18-2019, 12:30 PM | #1 |
2657
Rep 6,290
My sensor has been showing basically full for most of the time even though my exhaust is smelling a lot like oil and I know I'm burning some. My valve cover is also leaking.
I measured my oil and arrived around 500ml short of the 6.5L capacity last oil change even though my gauge was full and one day my reading showed 1/4 and the next day full. And I do understand the 20 min capacity update although a few months back I got a add 1 liter warning while driving on the highway and as soon as I added the liter, restarted the car and let the sensor do it's loading it was showing full before 20 minutes so I dunno anymore. So would you change the sensor? I'll probably order it along with the valve cover. I just hate throwing parts at something that isn't actually broken so how did your oil level sensor failed? |
09-18-2019, 08:08 PM | #2 |
17315
Rep 18,737
I wouldn't change the oil level sensor.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
09-18-2019, 08:17 PM | #3 |
2657
Rep 6,290
Since you know a lot about these... what do you say on the 500ml of oil short? Are these sensors supposed to be somewhat very accurate or it's normal? I understand out of that 500ml a few ML is clinging to the surface it's touching as well some may have spilled a little bit.
I am also a about 74k miles and I noticed it's definitely leaking/seeping (oil crud all around it) as well so must be original. |
09-19-2019, 12:56 PM | #4 |
Art Collector
2425
Rep 3,448
I’m at over 200k miles and mine is original. During the the coldest winter days, it’ll sometimes just say “INACTIVE” instead of providing oil level readout, but for the cost of replacement that doesn’t bother me. There is also a code thrown as well, but no CEL of course.
If there is oil seepage around the sensor and it bothers you, consider changing the o-ring seal before doing the sensor itself. Seems like an unnecessary expense unless it’s going totally haywire. I’d say it also depends on how much oil you’re leaking/whether you rely on the sensor to keep your oil topped up.
When I'm dead, just throw me in the trash.
09-19-2019, 04:30 PM | #5 | |
Robot
1685
Rep 2,191
09-19-2019, 04:38 PM | #6 | |
2657
Rep 6,290
Gauge read full. |
09-19-2019, 09:05 PM | #8 | |
17315
Rep 18,737
09-19-2019, 09:23 PM | #9 | |
2657
Rep 6,290
Guess when it fails it's really more the connector/communication and it would be much more erratic? |
09-20-2019, 12:41 PM | #10 |
Robot
1685
Rep 2,191
Oh... My bad. I didn't read your very first paragraph of your first post up top where you said that. I thought you were estimating that the 1/2 mark on the e-dipstick corresponded to 500ml (which it usually does, but it's not that precise).
TheMidnightNarwhal2657.00 |
09-20-2019, 02:09 PM | #11 |
Rep 15
Drives: 2008 328i Touring (E91) TiAg
Just replaced mine about 3 weeks ago. Had oil level low warning come on on the way to where I was driving. 30min later I drove to the store to get oil and it said level was full. I dont have any leaks, so I figured something else was going on. Next day I threw the code for oil level sensor. Had it replaced and replaced the seal at the same time. No problems now.
09-20-2019, 08:42 PM | #12 | |
2657
Rep 6,290
Could a leaking valve cover find it's way all the way there and to the rear of engine near transmission? |
09-21-2019, 07:29 AM | #13 | |
17315
Rep 18,737
I still suggest cleaning the connector first and see if the oil level sensor changes the behavior you have been observing. Considering the level of oil collected on your connector, it's start with cleaning it first.
09-21-2019, 10:39 AM | #14 |
488
Rep 1,309
I've been worrying about the level sensor on my car recently... Up until 3 months ago, I was leaking or burning 1 quart for every 2000 miles, and the level would slowly go down as the miles racked up.
During the last 3-6 months, though, it has shown 100% all the time, up until the point that it suddenly reported low and 0% on the BC oil level gauge. I added a quart, and bam, 100% again. It is still 100%. Is it low? Can I add a dipstick to this car??? |
