USB and aux not working after cic upgrade
09-18-2019, 06:00 AM | #1 |
Rep 14
Hello everyone I have 2008 e90. I have Tcu/mulf2 factory installed. I upgraded from ccc to 2013 cic unit but my usb and aux in the armrest is not working, on the radio it say aux active but you can’t change the volume also Bluetooth is not working also. Any help would be greatly appreciated. Thanks
09-18-2019, 06:37 AM | #2 |
Rep 55
Did you do any coding to the new cic? It may not have come from a car that had usb so the cic doesn't know it's there? You'll have code the Bluetooth to activate it in the cic.
I just did a retrofit on my non idrive car with a cic that had Bluetooth but since my car wasn't coded for it originally I had to tell my car it was one and reflash the cic. Once that was done everything worked again |
09-18-2019, 09:50 AM | #3 | |
Rep 14
09-18-2019, 07:00 PM | #5 | |
Rep 14
Do I still need to add $644 as the Bluetooth is in the mulf2 |
09-18-2019, 08:55 PM | #6 |
Rep 55
If your car doesn't have a VO of showing Bluetooth being active then yea you'll need to add $644.
I had mulf2 before my cic retrofit but Bluetooth wasn't active. It only became active when I added $644 and changed the cic to say it was active. Basically anything with the keyword Bluetooth or BT I changed to activ. It's what worked for me |
09-19-2019, 02:33 AM | #7 |
1911
Rep 13,104
http://www.e90post.com/forums/forumdisplay.php?f=122
http://www.e90post.com/forums/forumdisplay.php?f=368 Did you change the vin in the new cic to match your car? the newer Nav's are usually paired with a combox . Better go to the idrive and coding subforums for more detailed answers. |
09-20-2019, 12:03 AM | #8 |
98
Rep 121
If you're only doing ccc->cic, you only need to add #0909 and $6VA. Your vehicle order should already have $639 and $6FL. Did you 1. use a non-manipulation profile, 2. change the FA/VO, 3. execute FA_WRITE to CAS and FRM/NFRM, then 4. change the ECU to CIC and finally 5. execute SG_CODIEREN? The final step is where the new configuration is written to the CIC. FA_WRITE only changes the vehicle order, it doesn't actually write the settings to the CIC.
(I wrote a tutorial btw) |
09-20-2019, 09:13 AM | #9 | |
295
Rep 2,202
You can double check CIC trace file if it was coded correctly. Should see MULF_high or so.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
09-20-2019, 03:35 PM | #10 | |
Rep 14
Yes I did the above only thing is how do I know I was using a non manipulation profile. I tried doing a sg_reset I got error |
09-20-2019, 11:40 PM | #11 | |
98
Rep 121
See the screenshot below. Also, to my knowledge you cannot code the TCU or the MULF2 without an ICOM. But you shouldn't need to if you aren't replacing your TCU/MULF2; I did not do SG_RESET when I did a CIC retrofit. Coding the CIC with manipulation off was enough. |
09-21-2019, 05:45 AM | #12 |
456
Rep 2,749
you can code mulf or combox without icom(MOST) on e9x, headunit is acting as a gateway from K-CAN to MOST
you cannot code MOST modules on some early e60 and some e65 cars
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
09-21-2019, 06:22 AM | #13 | |
Rep 14
also I am using a plug n play harness with emulator i don’t think that should be the issue but just some more info |
09-21-2019, 06:25 AM | #14 | |
Rep 14
09-21-2019, 11:35 AM | #15 |
98
Rep 121
I got errors coding the TCU as well. (I originally attempted to retrofit a MULF2 and eventually gave up, and moved on to a combox.) I don’t think you can code the TCU or MULF2 without an ICOM, but again I don’t think you need to. Just code the CIC.
Also, since your emulator is plug and play, try removing it temporarily to code your CIC. You can put it back on after your trunk modules are working, or script activate the CIC. Last edited by FaxData; 09-21-2019 at 01:34 PM.. |
09-21-2019, 12:15 PM | #16 |
1911
Rep 13,104
Up to 3/07 build you can code most modules with and
K/D can but after that its not firmly known is K/D can is enough. The two profiles currently supplied with the Bimmergeeks downloads are Factory and Manipulate. Factory reads the VO files back into the selected module. This is called blank file programming but its not its VO coding. Man reads the Man files you have modified back into the module. Profiles select which options the files are read from or whatever option you want when you make a new profile. Last edited by ctuna; 09-21-2019 at 12:21 PM.. |
09-21-2019, 08:14 PM | #17 | |
Rep 14
09-22-2019, 01:42 AM | #18 |
98
Rep 121
09-22-2019, 06:39 PM | #19 | |
Rep 14
This is the one I have http://www.ebay.com/itm/Plug-and-Pla...ss!11735!US!-1 Last edited by Mmouse; 09-22-2019 at 06:58 PM.. |
09-23-2019, 01:05 PM | #20 |
98
Rep 121
Ok, since Bluetooth is working, your TCU is active and working. And since AUX is working, your MULF2 is [at least partially] working and your CIC is properly coded. First, I would try a variety of different USB drives, maybe there's an issue with the USB drive you've been testing? And make sure that the drives are formatted as FAT32 and not NTFS or HFS or anything like that. The car only supports FAT/FAT32, as far as I know.
09-23-2019, 01:09 PM | #21 |
1911
Rep 13,104
Can't you change the Vin in the Head Unit using Tool32.
Thus avoiding an emulator. Also might be worth looking in the Head Unit Files so see whats enabled. Do a search for USB in same. |
09-23-2019, 03:44 PM | #22 | |
98
Rep 121
But... it's worth seeing if the USB/Aux issues can be resolved first. If it's truly the emulator that's the problem, I would ask for a refund from the eBay seller. mmouse, in case you don't see my post above, please try the different USB drives as I suggested. |
