BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Advice on tire size
      09-18-2019, 01:16 AM   #1
deepat04
51
Drives: 2019 M550/2019 330 M Sport
Advice on tire size
I have ordered a set of 20x9 25offset 20x10.5 38 offset wheels
I would like to run a 285 in the rear or if possible a 295.
what are the pros cons of running the wider 295 vs the 285 and what would be the recommended front tire size?
Thank you in advance
dalia619.00
      09-18-2019, 05:30 PM   #2
Dobie Dog
Dobie Dog's Avatar
Drives: 2021 F97 X3M Comp
I run 20x9 ET25 and 20x10.5 ET35 with 245/35/20 and 265/30/20 because I am lowered. You could easily run 295 or maybe 305 on the rears if you are not lowered.
Life is short...Drive fast
Appreciate 6
      09-18-2019, 08:19 PM   #3
deepat04
51
I am lowered on HR Springs..
I would at minimum like to run 285 if possible but 295 would be ideal..
Your Car looks great! Well done
Appreciate 2
      09-18-2019, 09:04 PM   #4
AddyDaddy
AddyDaddy's Avatar
Drives: i5 M60, M5's, 535.335, M550i
295's would look better than 275's the car comes with. I put 10mm in front and 12mm spacers on rear and I'm still looking for wheel well to be filled a little more in rear
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M ,
2013 M5 , Individual Silver, Bolt ons-Straight piped
2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete
2024 i5 M60 Cape York Green
      09-19-2019, 11:26 AM   #5
dalia6
Drives: 15' M3 Dinan Stage 1, 20' M550
@AddyDaddy- do you have 295s on the rear of your car?
      09-19-2019, 05:41 PM   #6
AddyDaddy
AddyDaddy's Avatar
No, stock 275's with 12mm spacers. I want to go to 295's since it's a minor increase in width but will still have a visual difference
2018 750M ,
Appreciate 2
      09-19-2019, 09:31 PM   #7
deepat04
51
Where did you get your rear diffuser from?
      09-20-2019, 12:47 AM   #8
deepat04
51
Also still would like some advice on the tire size, would a 295 rear and 255 front be okay on a lowered M550? HR springs
      09-20-2019, 06:16 AM   #9
Dobie Dog
Dobie Dog's Avatar
https://www.shopbmwusa.com/PRODUCT/5...centerid=67600
      09-20-2019, 08:43 AM   #10
CLABRO
THUNDER UP!
CLABRO's Avatar
Drives: BMW M Sport G30
Yes, it would be okay. Just make sure your overall tire diameter (height of the tire) is consistent in the front and rear.
G30 l Alpine White l M Sport Package l Executive Tier l Icon Adaptive Full LED Headlights l Mocha Nappa Leather l Multi-Contour Seats l Drivers Assistance Package l Drivers Assistance Plus Package l Dynamic Handling Package l Parking Assistance Package l Bowers & Wilkins Diamond Surround Sound System l M Sport Brakes l Apple Carplay
      09-20-2019, 12:43 PM   #11
deepat04
51
I am getting
255/35/20
295/30/20
Is that the proper size?
      10-14-2019, 12:36 AM   #12
deepat04
51
Bump for conformation
      10-14-2019, 08:28 AM   #13
AddyDaddy
AddyDaddy's Avatar
I can't confirm but 295/30's is what I want in rear but I have spacers and not lowered.
2018 750M ,
      10-14-2019, 11:37 AM   #14
CLABRO
THUNDER UP!
CLABRO's Avatar
I am getting
255/35/20
295/30/20
Yes, those would be good choices. Just make sure your rear wheels will be at least 10" wide (so 20x10 in your case) for the 295 tire. Looks like you ordered 20x10.5 so that will be perfect.
You could technically run a narrower wheel like a 9.5" on that size of tire, but 10" is the minimum recommended wheel width for a 295 tire. Anything less than 10" on that tire will make the tires buldge which isn't ideal.
Put up pictures when you get them mounted!
Appreciate 2
      10-14-2019, 06:05 PM   #15
deepat04
51
Thanks for the response. Def will! Their a custom forged version of the OEM wheels with some changes, size offset, elected for a 3 inch concave stance in rear and went slightly darker on the color vs oem...waiting for them to arrive now!
Appreciate 2
clee1982796.00
540iSUP703.00
      12-12-2019, 09:28 PM   #16
cbarden
49
Drives: M5
So, did you put 295/30/20 in the rear? Got any pics? My buddy selling a set of used 20x9 wheels and I'm thinking of buying them and fitting some continental tires in 295/30 also.
      12-12-2019, 10:06 PM   #17
Superjackson
122
Drives: M550i
You can do a 265/35-295/30 with those wheels easily. If it were me, I'd try a 275-305 on those wheels but I'm not sure how stiff your springs are xD
      12-13-2019, 10:40 PM   #18
TexasM550i
TexasM550i's Avatar
Drives: 2018 BMW M550i xdrive
On my M550i I'm running 20×10.5 in the rear and 20×9 In the front with 275/35R20 and 305/30R20's. I had the 285's and 290's, but liked the look and ride with the these the best. No rubbing issues.
2018 M550i xdrive, DME Stage 2
Appreciate 4
      12-27-2019, 09:49 AM   #19
rif75
France
64
Drives: BMW M4 LCI ZCP and BMW M5 f10
Hi all and merry Christmas
I would like to know if someone has tried to put 265 front and 295 on OEM 20 wheels. I am going to buy a G30 540i rear wheel drive and would like to improve traction since I am looking for a stage 3 and hopefully more than 500hp.
Thank you
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
      12-31-2019, 10:58 PM   #20
deepat04
51
Originally Posted by TexasM550i View Post
On my M550i I'm running 20×10.5 in the rear and 20×9 In the front with 275/35R20 and 295/35R20. I had the 285's and 290's, but liked the look and ride with the 295's the best. No rubbing issues.
One of the cleanest M550 I have seen. Well done
What are your wheel offsets?
      12-31-2019, 11:01 PM   #21
deepat04
51
I did go 295 fit no issues.
This is the size to go with IMO
Here are pictures without my floating OEM caps.
Appreciate 5
      01-06-2020, 10:38 AM   #22
TexasM550i
TexasM550i's Avatar
Hi, thanks! I'm not sure of the offset, but the wheels are BMW MSport Wheels 86281, 86285, 20×10.5 R 20×9 F. Hope that helps.
Search this Thread:
Advanced Search
5post
