Bimmerpost
4 Series
Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Jb4 install with pics
      09-17-2019, 11:21 AM   #1
TheBenchmark
59
Drives: 2020 M340i
Model I ordered
https://burgertuning.com/products/jb...0-toyota-supra
Tools:
Flathead screwdrivers
7/64 allen if using bluetooth connect
Total time with intake 30 minutes
Next:
Grannas downpipe
All the dreadful grey trim to black
Lowered
Cf goodies
Forged wheels
Appreciate 2
vicfalc09211.00
VipinLJ1941.50
      09-17-2019, 03:58 PM   #2
Alexey
31
Drives: M340
Very interesting 0-60, 60-130 stock vs JB
      09-17-2019, 04:20 PM   #3
TheBenchmark
59
Drives: 2020 M340i
Should have some data this Sunday. Currently on Map 1 and throttle response seems better
vicfalc09211.00
      09-18-2019, 12:06 PM   #4
iPetey
iPetey's Avatar
69
Drives: 2020 BMW M340i xDrive
2020 BMW M340i  [0.00]
Thats interesting, because when i emailed BMS, they told me that the one i got (b58) was the correct one for our cars.
https://burgertuning.com/collections...oducts/b58-jb4
      09-18-2019, 12:11 PM   #5
joes_m340
joes_m340's Avatar
23
Drives: 2020 M340 xDrive
Specifically the 2020 B58? Am I the only crazy person that doesn't just want to throw the previous model JB4 on my car? The tune for the previous model isn't accounting for the changes our version of the B58 has. I'm not saying it's an issue, just not ideal.
2020 ///M340
      09-18-2019, 12:19 PM   #6
iPetey
iPetey's Avatar
69
Yes, posted the emails in the thread i started as well.
      09-18-2019, 12:36 PM   #7
TheBenchmark
59
Drives: 2020 M340i
I'm sure the older b58 jb4 would work on the newer car.
I was told directly from Terry to order the Supra stuff.
I've been driving the vehicle for a day now and it's noticeably more fun.
      09-18-2019, 02:39 PM   #8
joes_m340
joes_m340's Avatar
23
Saw that, thank you! It was never a would it work thing for me, it was more is it optimized for our car.
2020 ///M340
      09-18-2019, 02:44 PM   #9
iPetey
iPetey's Avatar
69
i agree but now i wonder what's the better option here? i don't want to have some sub-par ish, lol
      09-18-2019, 03:01 PM   #10
joes_m340
joes_m340's Avatar
23
I'm just envisioning the tune on that JB4 is designed for the 2018 spec'd motor, leaving a lot on the table in terms of gains. Either way you're getting gains.
2020 ///M340
      09-18-2019, 05:58 PM   #11
bimmer813
Drives: 2023 M4, 2024 X5 M60
The hardware will be identical for both, and I assume the tuning/maps will be as well.
All you will want to do when receiving yours is update to the latest firmware (whether via the bluetooth module/app or the USB cable).
      10-05-2019, 10:44 AM   #12
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Congrats OP
https://x-ph.com/sale/
Phone number 702-494-9435
      02-09-2020, 09:09 PM   #13
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
I know this is a really old thread but I have a few queries regarding the install.
I have a G20 330i but I assume the basic part is the same regarding pulling the obd2 cable into the car.
1. I opened the compartment under the hood and snooped around trying to find a way to get the cable inside. I saw a circle in the firewall that looks like it’s covered with the same material as the rest of the firewall (but it has a circle cut out). It was below the plastic part for water to drain. How hard was it to push it out into the driver’s side footwell?
2. Inside the car, under the steering, do we have to remove the bottom panel by unscrewing the two locks? I looked around today, without undoing the locks and dropping any trims, and did see an opening in the footwell on the firewall that looked like it was the other side of the circle in the engine bay side. But I’m not sure. Is that the opening?
If you could post a few pics of how you got the obd2 cable inside you car, I’d be grateful.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      02-09-2020, 09:12 PM   #14
TheBenchmark
59
Drives: 2020 M340i
1. I opened the compartment under the hood and snooped around trying to find a way to get the cable inside. I saw a circle in the firewall that looks like it's covered with the same material as the rest of the firewall (but it has a circle cut out). It was below the plastic part for water to drain. How hard was it to push it out into the driver's side footwell?
It's plastic so I just pressed on it.
2. Inside the car, under the steering, do we have to remove the bottom panel by unscrewing the two locks? I looked around today, without undoing the locks and dropping any trims, and did see an opening in the footwell on the firewall that looked like it was the other side of the circle in the engine bay side. But I'm not sure. Is that the opening?
I removed the two screws for the plastic cover under the steering column.
If you could post a few pics of how you got the obd2 cable inside you car, I'd be grateful.
I can take some photos of it tomorrow
VipinLJ1941.50
      02-09-2020, 09:16 PM   #15
VipinLJ
Petrolhead
VipinLJ's Avatar
Thank you very much. I appreciate that a lot.
Edit - Just added a few photos.
Current:
Appreciate 2
g20
