Son of a gun.. 100k miles.
09-14-2019, 06:37 PM | #1 |
///Kenney
86
Rep 750
Well. Title says all just hit 100k miles on my 09 335i and I have an oil leak! Coming from oil filter housing unit i am pretty sure. Obviously visible leaks at the OFH but today found 2 small drops of oil on my garage floor. I have the under belly pan on and it’s right under neath the engine. Could it be something else?
Do you think I may have it over tight and ruined the o rings? It doesn’t look like it’s leaking from where it connects to the manifold (gasket)
2009 335i / sedan / silver & black / stock / 187's / sport and premium package - wife's ( purchased 09/01/2015 )
2006 330xi / sedan / black and saddle brown / sport, cold weather & premium / stock - mine! ( purchased 04/01/2014 ) |
09-15-2019, 07:18 AM | #2 |
231
Rep 5,691
My guess based on your picture is either you have installed a crummy aftermarket filter and oring which a huge no-no, or you have split the oring on your filter.
When was your oil last changed? |
09-15-2019, 08:01 AM | #3 |
17314
Rep 18,737
So just to be clear, the OFH bolts to the cylinderhead, not the (intake) manifold.
If you did the oil change, which it sounds like you did, you may have not placed the large 0-ring in the correct groove in the oil filter cover. I suggest you reopen the oil filter cover and check the installation of the large o-ring.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
09-15-2019, 02:02 PM | #4 |
///Kenney
86
Rep 750
I did my last oil change 2k miles ago. Always use top oil and Mann filter. Have done my own changes 5-6 times never a problem. At 102k miles right now.
Their is a puddle on my under pan belly. I will take another photo |
09-15-2019, 02:02 PM | #5 | |
///Kenney
86
Rep 750
09-16-2019, 10:50 AM | #6 |
///Kenney
86
Rep 750
O rings on oil filter cap look fine. Their in the correct spot. Still leaking. It’s piddling on my under belly. Lots of stained parts with oil. Will post a new picture but prob going ahead and ordering the gasket part and installing
09-16-2019, 11:01 AM | #7 |
Because Racecar
126
Rep 266
Odds of the OFHG leaking so much to pool under the belly pan is slim.
If it's saturating the belly pan and dripping through I'd be more likely to guess an Oil Pan Gasket which is very common. Nonetheless, if your OFHG is leaking that much then it's possible for it to be falling onto your drive belt and that should be your focus.
Antetokounmpo1551.50 |
