Seat buckle is wrong way - how to fix?
09-14-2019, 05:39 PM | #1 |
2659
Rep 6,290
This isn't normal right? Guess I have to unbolt the seatbelt off? On my driver side it's oriented properly but not on the passenger.
09-14-2019, 06:27 PM | #2 |
2659
Rep 6,290
Took out the seatbealt anchor at the bottom and the stopper for no damn reason it wouldn't clear the thick stitching.
Pried at it like crazy and got it the flip itself finally... Last edited by TheMidnightNarwhal; 09-14-2019 at 07:40 PM.. |
09-14-2019, 06:59 PM | #3 |
Is it the shoes!?
3884
Rep 5,112
It happens from time to time. You can fold the seatbelt webbing in on itself within the buckle and get it back the right way. It's a little tricky but it's possible to do without unbolting the seatbelt.
TheMidnightNarwhal2658.50 |
09-15-2019, 03:02 AM | #4 | |
49
Rep 395
The issue is now the belt is creased and it slips off the arm extender. I have tried starch spray and iron to flatten the belt and no luck. In the end just removed the fuse for the extender. I may need new belts |
09-15-2019, 06:45 AM | #5 |
866
Rep 5,450
I have had this happen also, twists and goes back inside the B pillar, you just have to work it through the upper mount with another twist to get it back straight, I took off the b pillar trim to figure out where the twist was and untwist it the right direction.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
