Limp mode when using turbo
09-14-2019, 02:27 AM | #1 |
Rep 10
Hey Guys,
Sorry if I sound silly in advanced. I’m new to cars. Driving: BME 335i 2009 Problem: Filled up petrol, checked tyre pressure (made front 32 and rear 38), got the car valeted. Drove off and when the car hits the turbo/high revs in sports mode – it goes into limp mode and the check engine light turns on. When I restart the car, the check engine light turns off and the car sounds and drives normal. As long, as its kept in D mode it drives fine no issues. When in place the car into M/S (sports) and click the sports button below it (separate question why does it have a sports button and a M/S that I need to shift into sports) and then put my foot down – it drives well until the turbo is meant to come into play then goes into limp mode. Again, restarting the car ‘fixes’ it. I called the NRMA guys, who plugged the car into the computer thing – strange thing is it found no error codes. So he searched for faults and found the following (I have no clue what the mean) - Engine DME Motor Electronics - ABS-DSC Dynamic control stability - CON Controller - CTM Convertible Top Module - FLA High beam assist - FRM2 Footwell Module 2 - INSTR Instrument Cluster No garage is open till Monday. I guess I have 2 main questions 1) What do you think is wrong? 2) Are those a lot of faults considering I got the car serviced 3 months ago To Note: I had the car enter limp mode 1 month ago, where there was a misfire of cylinder 4. The mechanic swapped out all the coils and switches associated. It drove absolutely fine till today. Thanks guys, sorry again if I sound stupid. |
09-14-2019, 07:04 AM | #2 |
231
Rep 5,691
It’s likely they aren’t using bmw specific scanner and thus the reason why no codes show up on their scanner. With no fault codes no one can really make an educated guess here.
09-14-2019, 08:58 AM | #3 |
140
Rep 445
Without specific OBD fault codes, it's impossible for anyone here to do anything but guess. But, a common cause of exactly that behavior is failing VANOS solenoids.
Regards, Ray L. |
