Bimmerpost
4 Series
Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications M340i Low engine oil warning at 3000 miles
      09-10-2019, 09:52 PM   #1
0xdq
0xdq's Avatar
36
Drives: BMW M340i
Is it normal?
      09-11-2019, 03:21 AM   #2
xacoffeemx
33
Drives: 2017 320i, 2020 M340i
Originally Posted by 0xdq View Post
Is it normal?
This seems completely normal as I've encountered this 2 times already within the last 3,750 miles.
The first time came on at around 1,500 miles.
The second time was at about 3,500 miles.
I just bought a case of 12 quarts of oil from ECS because I know I'll be needing a quart every 2 months or so..
Appreciate 2
      09-11-2019, 05:05 AM   #3
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
This is most likely not a normal symptom. Take it to the dealer as soon as possible.
Appreciate 3
      09-11-2019, 08:01 AM   #4
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
I don't think this is normal, car should not need oil every 2-3k
      09-11-2019, 11:11 AM   #5
gnr4all
Drives: 2020 M340i xDrive SB
I had the same thing at 3500 miles
      09-11-2019, 05:11 PM   #6
DonTheDon
16
Drives: M340i, 340, mustang
I needed it at 4k
      09-11-2019, 07:07 PM   #7
EXE46
EXE46's Avatar
Drives: 2020 M340i RWD Aka New E39 M5
Not good, you'll never hear of this on a Lexus ever. I hope i don't have these issues on my car in the future. If car was over 150k miles I could understand needing oil prematurely but this is unacceptable for a new car.
Prior's: E36, E46 x2
Appreciate 3
      09-11-2019, 07:34 PM   #8
themnmd
themnmd's Avatar
Drives: 23 X5MC
Any more the 1 quart per 10k not normal, check it out for sure
      09-11-2019, 07:37 PM   #9
Deltusurf
Member
Drives: Arctic White 650i, 2020 M340i
2013 BMW 650i  [0.00]
This was a known issue with my 2013 650i. My dealer just always gave me free oil and I kept it in my trunk to use when needed. They told me that those turbos were known to burn through oil. Maybe it's the same with this engine. Thanks for mentioning this, it's nice to know what to expect.
Appreciate 2
      09-11-2019, 09:37 PM   #10
raptorapture
raptorapture's Avatar
Drives: 2020 m340i
2020 M340i  [0.00]
Mine came on at 2500~ miles, dealer changed the oil and what not for free.
Appreciate 2
      09-11-2019, 11:46 PM   #11
Wineguy
Drives: M535,328i,328d,330i
I’ve got over 5K miles and never received that warning. I changed oil at 1K as suggested by my service manager. Had my car for 2 1/2 months.
On another note, took car in for what I thought was a software issue.
Received a call 30 minuets later asking if I’ve had problem starting car. I responded no, my service Mgr said my key won’t start car.
They’ve had car a week and found out the BDU unit had to be replaced. Had to fly in from east coast.
Maybe tomorrow if they can get the programming to load properly.
      09-19-2019, 06:35 AM   #12
bones
123
Drives: 2020 M340 RWD
I got the the warning that my M340 was low last night. It just hit 3k. I put oil in shortly after the warning and the level checked out as good.
This morning in traffic I was smelling oil burning. I opened my hood when I got to work and I've definitely got some kind of smell going on. Exhaust smells fine. Engine bay smells like hot plastic/oil. No smoke.
Appreciate 2
      09-19-2019, 12:03 PM   #13
CrownRoyal79
CrownRoyal79's Avatar
Drives: BMW 435i
My 2016 435i needed a quart at around 5k and never needed another after that. My M340i just crossed 5k and it just asked for a quart of oil.
Maybe this is normal for the break-in period? Maybe the oil from the factory is different? If I ever needed to add more than 1 quart between oil changes I would suspect that there's something wrong.
0xdq36.00
      10-11-2019, 11:54 PM   #14
F30.N54.lol
Tech
South Korea
13
Drives: M340 /GTR
Lol @ comparing this to a lexus. Lexus engines are ok and reliable , but nothing close to BMWs engine tech , smoothness and output.
Appreciate 3
      10-11-2019, 11:55 PM   #15
F30.N54.lol
Tech
South Korea
13
Drives: M340 /GTR
I would be worried if its still eating this much oil after the first oil change. At this point i would write it off to "breaking in "
      10-12-2019, 12:28 AM   #16
Antec800
128
Drives: 340i x drive
Same at 4K miles
      10-12-2019, 09:43 AM   #17
EXE46
EXE46's Avatar
Who are you again? I have had prior BMW's and none needed oil at such low miles. Lexus V8 high performance engines, granted NA and no matter how hard an ISF/RCF/GSF/LC are driven they don't use oil prematurely.
Funny you mention smooth, Lexus makes some of the smoothest engines on the planet, besides smooth is boring. An ES350/LS460 is smooth but extremely boring cars to drive.
      10-12-2019, 12:37 PM   #18
Weiner0123
Weiner0123's Avatar
417
Drives: 2020 m340i. 2013 328i
7K KM, Did the correct break in procedure, never push the car hard until it warmed up and did a oil change at 3500KM, Thing has been at Max line and has not moved... Even after spirited driving sessions.. so definitely something wrong I would get it checked out
      10-12-2019, 03:46 PM   #19
F30.N54.lol
Tech
South Korea
13
Drives: M340 /GTR
Iam just a nice friendly guy. And bingo at why you shouldn't compare oil consumption between NA and turbo vehicles .
Nevertheless , hope your oil consumption stays below the BMWs allowed spec ... there is a good bulletin on this.
EXE462100.00
      10-13-2019, 04:37 AM   #20
evo2335
Drives: G37 IPL (340i on the way)
Mine asked for oil around 4500 miles. Just took it to the dealer and it was topped off. iirc, my 340i did the same thing after 3-4K miles as well.
      10-13-2019, 08:29 AM   #21
EXE46
EXE46's Avatar
If it's a one time thing that's ok, probably we could all just change out the factory oil early. I will wait and see, mine just hit 2k miles, keeping fingers crossed. I have not used LC yet either. I hear LC puts lots of stress on the drive-train.
      10-14-2019, 09:36 AM   #22
raptorapture
Drives: 2020 m340i
2020 M340i  [0.00]
Update: currently sitting at 4041 miles and I have had the 2nd low oil warning come on as of yesterday evening (approx. at 4035 mi).
Going to try to bring it in today as this should not be burning through a majority of the oil every 2000 miles.
Last edited by raptorapture; 10-14-2019 at 10:52 AM.. Reason: Inserted previous reply for reference.
Appreciate 2
g20
