Rear Camber After-Market Bolts?
09-10-2019, 05:26 AM | #1 |
Rep 3
I had an alignment done recently on my 2008 328xi. The shop explained that the rear camber can't be adjusted any further and it is out of spec with the manufacturer recommendations. They told me there are after-market rear camber adjustment bolts available that can be installed to allow for more adjustment. Does anyone have part recommendations or experience with this?
Thanks |
09-10-2019, 09:34 AM | #2 |
4276
Rep 9,209
I'm aware that isn't the answer you came on here for, but: go to another shop. Two reasons for factory eccentric bolt not being able to adjust camber within factory specifications: #1 damaged parts #2 tech incompetence.
orange_3280.00 |
09-19-2019, 01:19 AM | #5 |
Hola
70
Rep 407
There are arms to get more camber in the rear, haven't heard of just a bolt, but unless you're looking to go full stancey boy, they aren't really needed. Like others said, find another shop.
10-11-2019, 07:02 PM | #6 |
79
Rep 189
recently i was told very similar by a tire shop, and even that 1 bolt is seized. i took car to BMW, and they were able to allign the car to spec on all tires without any issue and no need to replace any bolts or anything seized. IMO shops charging flat rate for allignment just want to do a quick toe allignment so steering wheel is straight and they dont care about the rest even though it effects tire wear and overall performance.
The original BMW rear suspension already has essentric washer and essentric bolts to allow a good range of adjustment unless you have some serious subframe or control arm damage. |
10-14-2019, 11:02 AM | #7 | |
Guest
Rep n/a
Drives:
The more people actually understand what actually happens during an alignment, cause/effect of each adjustment, and the actual parts involved, the quicker these types of issues can be resolved without having to go to 8 different independent shops + the dealership just to end up with half decent toe settings at the end of the day. |
