(Dumb Mistake): Homelink Mirror Fail
09-09-2019, 08:16 PM | #1 |
31
Rep 92
Drives: E91 6spd // E46 M3 LSB
I need some help with a dumb mistake I made. I got lazy and didn't disconnect the car battery (yes...I know, low voltage, lazy etc.) When I was about to connect the last wires up, I accidentally shorted the red/violet wire with the ground wire. I'm looking for some guidance to see if I have to just get a new/used dome light/sunroof control module? or can I reset this somehow using Toolset32 or something similar?
Homelink mirror still works (compass + other functions). The following do NOT work anymore:
09-10-2019, 01:59 AM | #2 |
456
Rep 2,749
check fuse for FZD module
it is not seen on you module list
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
09-10-2019, 02:25 AM | #3 |
31
Rep 92
Thanks!
I decided to go into the fuse box and write down any possibly related modules from the table and it happened to be #62 (alarm siren) that affected all the other functions (vanity + cabin lights, alarm system, passenger airbag, surprisingly). Glad it was only a single fuse and not something more serious. |
