Engine splash shield
09-07-2019, 10:17 PM | #1 |
Rep 5
Hey everyone, i got a 2010 335i e93 that is missing the engine splash shield and the drivers side front wheel shield as well. I been reading a whole bunch of threads but still its not clear so My question is, are the coupe and the convertible parts the same? Any input is appreciated
09-07-2019, 10:55 PM | #3 |
Rep 5
i actually did look up realoem and a few other sites but i couldn't find a definitive answer so thats why i figured i might get some help here from someone with first hand experience, obviously not you lol but thanks for nothin
09-07-2019, 11:03 PM | #4 |
231
Rep 5,691
Are you kidding me? Look up the part on real oem that you need. You can from there see every car that uses that part number.
As I said, do your own research |
09-08-2019, 12:50 AM | #5 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
Does it have an msport front bumper
Common sense is a flower that does not bloom in everyone's garden
09-08-2019, 04:21 AM | #7 |
49
Rep 395
The SE has a different shield than the Msport.
Which model you you have? I used this guide for conversion and the OP had a very good guide and picture shows both SE and Msport splash shield. https://www.e90post.com/forums/showthread.php?p=8140019 Last edited by Sayek; 09-08-2019 at 04:30 AM.. |
Altin0.00 |
09-08-2019, 05:04 AM | #8 |
Rep 5
09-08-2019, 06:47 AM | #9 |
17309
Rep 18,733
The splash shield is different between the M-sport and non M-sport, and unique to the E93. The splash shield is different between the E93 RWD and Xi.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
colorado.e9x3065.50 Altin0.00 |
09-08-2019, 07:37 AM | #10 |
863
Rep 5,448
I retrofitted an m-sport bumper to my 08 e93 and the splash shield has e93 stamped into the plastic, there are some extra braces so maybe not the same as the e92, checking realoem parts are different e92 to e93 in all instances with or without msport and facelift or non facelift. Best thing to do op is put last 7 of vin in OEM and lookup the part numbers.
