Front main seal problem.
09-07-2019, 10:13 AM | #1 |
Rep 12
I went to replace the fromt main engine seal on the n54 engine. Used the puller
And all however when i went to pull it out in seems to have bent around the Crankshaft and i cannot get it out. Any replied would help as this is my main form of transportation.... PLEASE HELP |
09-07-2019, 10:48 AM | #2 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
09-07-2019, 10:51 AM | #3 |
Rep 12
09-07-2019, 10:53 AM | #4 |
Rep 12
When i went to pull the rest out after it got stuck it seems to have bent around on one side tryed pulling it out with a pair of needle nose pliers but that didnt get it so its just stuck in there now should i cut it and get it from the inside?
09-07-2019, 11:07 AM | #5 | |
1903
Rep 6,968
You have to be really carful not to scratch or score the inside of the crank seal fitting. |
09-07-2019, 11:09 AM | #6 | ||
Rep 12
09-07-2019, 11:23 AM | #8 |
Rep 12
Yes, it was leaking kinda bad, only once an oil change was done it would leak to about half full then the leak would stop, it was leaking onto the belt and one time I actually had to push his belt back onto the pulley. Slipped a quarter ways off
09-07-2019, 05:44 PM | #9 | |
1903
Rep 6,968
I can go into detail as to why you shouldn't even consider the BMW sealant, but I digress. Do this : 1) take a Q-tip and dip it is motor oil( run the Q-tip on the crank shaft inner ring. THIS IS SUPER IMPORTANT. 2) place the seal in the fitting, and line it up pertaining where the notches on the side are on the seal to the block's crease between the lower & upper portion of the block meet. They must line up perpendicularly. Start to slowly crank the seal in with tool, until you get to the notches. Stop 3) Fill the notches with Ultra Gray & run a bead of Ultra Grey around the entire outside of the seal. Let it set up for maybe 10 min. 4) slowly press the seal in with the tool, until its flush to the block. 5) run a bead on the inner & outer ring of Ultra Grey like you were caulking something in the house. 6) VERY IMPORTANT - do not start the engine until 24 hours have past. ULTRA Grey does not fully cure until 24 hours. You can run the car with a 30 amp battery maintainer or higher without the crank pulley & belt in place. I'd run the car for 20 min or so make sure the seal holds before you put it back together. Also, you might want to seriously consider the new crank seal plate made out of Aluminum they sell for $150.00. Especially, if your motor mounts are over 100k old. Better than potentially ruining an engine. |
09-07-2019, 05:59 PM | #10 | ||
Rep 12
09-07-2019, 08:30 PM | #11 | |||
1903
Rep 6,968
09-07-2019, 11:54 PM | #12 | ||||
Rep 12
09-07-2019, 11:57 PM | #13 | ||||
Rep 12
09-08-2019, 07:17 AM | #14 | |||||
1903
Rep 6,968
Otherwise, it looks like you might be able to grab on the metal part of the seal with a thin pair of locking pliers. Be careful not to break it off. Hopefully, you can get part of the seal out and then move to another part of the seal and pull on that. If you can get the lip of the seal out, then you are in business. If the lip is out, you can put the tool back in and then use a flat screw driver & a small hammer and bend the lip around the removal tool. |
09-08-2019, 07:34 AM | #15 | ||||||
Rep 12
09-08-2019, 02:30 PM | #16 |
1903
Rep 6,968
Did you get it out yet?
09-08-2019, 04:43 PM | #17 |
1911
Rep 13,103
Did you have the accessory belt failure where the belt
gets sucked into the Engine ruining the seal and possibly getting pieces of belt in the Engine? Or is this even the same thing? broken belt https://www.e90post.com/forums/showthread.php?t=1305990 http://www.bimmerfest.com/forums/sho....php?t=1231881 http://www.e90post.com/forums/showpo...3&postcount=23 http://www.e90post.com/forums/showthread.php?t=1477111 https://www.oxwerkzperformance.com/ |
09-08-2019, 05:02 PM | #18 |
Rep 12
09-08-2019, 05:23 PM | #19 |
1903
Rep 6,968
09-08-2019, 05:24 PM | #20 | |
Rep 12
