N47 rattle/vibrating noise
09-05-2019, 03:22 PM | #1 |
Rep 41
Hi guys just wondering if anyone can shed any light onto my issue
Had it for few months just cant pin point what it is. So it happens only when driving not in neutral. And between 1750 rpm and around 2000rpm. The noise is like a rattle vibration of something rubbin on something fast like a trim type rattle. Its coming from up front but sounds fairly loud but not 100 percent its inside or under bonnet. Its just really annoying now. Its on 2009 lci 318d e90.... i have had timing chain replaced and pulley and water pump done and noise came not long after but engine was removed to do work so trying to think wat could be which has been disturbed Thanks in advance Last edited by Mattsteele318d; 09-05-2019 at 03:47 PM.. |
09-05-2019, 04:04 PM | #2 |
3058
Rep 3,910
Right up until I read that the chains (and presumably tensioners, etc) were replaced, I was thinking that it could/would be the chains...though I guess that doesn't figure with it needing to be in gear to do it.
Does the noise stop when you press the clutch? Or only when you're out of gear? Does the noise change with rpm (between 1750-2000)? |
09-06-2019, 01:29 AM | #3 | |
Rep 41
09-06-2019, 03:45 AM | #4 | |
99
Rep 237
09-06-2019, 12:29 PM | #5 |
Rep 41
Unfortunately yeah that and the water pump were also changed at same time so cant be that either ha driving me mad
