Can manual cars be push started?
09-03-2019, 07:42 AM | #1 |
32
Rep 199
I believe my starter died yesterday. It cranked rough the first time i tried it (but did not start), i thought the battery was low, I put it on battery tender, tried again few hours later and nothing at all, no crank either. So I'm guessing it has to be the starter.
I'm just wondering, I know back in days when cars didn't have crazy electronics, manual cars could be push started. Can that be possible for cars of today? 2006 325i 6 speed manual.
09-03-2019, 07:46 AM | #2 |
146
Rep 295
Yes. I do it from time to time in my 2011 335i.
Find a bit of a hill, put it in 2nd gear. Turn ignition on (so you can see the fuel gauge level reading). Get it up to 15 mph or so and pop the clutch while giving some gas. Have also done this in reverse but that can be sketchy and more of a last ditch effort if you are parked on a hill. Also this is more of a trick with older cars but try lightly tapping the starter with a hammer. Sometimes a piece of debris gets stuck underneath one of the brushes, or a brush is hung up, causing incomplete contact with the commutator. |
09-03-2019, 07:47 AM | #3 | |
40
Rep 58
09-03-2019, 09:09 AM | #4 |
203
Rep 437
Yep. My starter died at a wawa gas station without any warning. I just asked a few young guys to help me push start it in 1st gear. Took a couple tries but it worked 😅
09-03-2019, 12:59 PM | #6 |
382
Rep 891
Yet another reason I’m happy I bought a manual e90. Speaking of the hills, I recently replaced a radiator which broke when I was replacing oil filter housing gasket. My car was parked on the hill where a live and it would be a challenge to get it to the spot where I could safely jack it up. Luckily, on a manual e90 you can pull the radiator out from the top, don’t need to remove any transmission heat exchangers from the bottom.
09-03-2019, 01:17 PM | #7 |
228i, m235i, n54 335i
Rep 43
FYI
08 335i and this doesnt work if the car is dead dead.
i was having an alternator problem and experienced this before changing it out with a new one. If there is no electrical when you put key in or push start 1 time (foot not on clutch) this does not work. you need dash lights. |
09-03-2019, 06:01 PM | #8 | |
95
Rep 112
Drives: 2020 LBB M2C
09-03-2019, 06:59 PM | #9 |
Art Collector
2425
Rep 3,448
Call me old fashioned, but why not plug in a scan tool/INPA/ISTA and see if there is a code for the starter?
Don’t get me wrong—it’s possible there isn’t one and your starter is still to blame, but I’d think it’s worth a check.
When I'm dead, just throw me in the trash.
09-03-2019, 07:27 PM | #10 | |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
The battery in my MR2 died when I was out and about. The MR2 is not a heavy car but was only w/my GF in a flat parking lot. Got it going and hopped back in (a couple of times) but the car just woudn't fire up even though there was still some juice the battery (enough to turn on the radio and gauges). Was too pooped out to continue and just called AAA. The car started right up w/a jump. Went straight home and bought/installed a new battery the next day.
2008 Black Sapphire 335i E90 Sport & Premium Pkgs - Cobb Stage 1+FMIC Sport map, Mishimoto FMIC & Alpina B3 AT Flash. See: My Build Thread.
09-04-2019, 08:36 PM | #11 | |
1007
Rep 2,108
I believe it is even written on the user manual, though I had read it like 13 years ago. If battery is fully dead, it may not start. I have a cigarette lighter usb charger with battery voltage display. I see the alternator takes over after 5 seconds or so when I start the car. It initially runs fully on battery power. Found it online. In the user manual it is under "Tow-starting" title, towards the very end. "Tow-starting If the electrical system fails, do not attempt to tow-start or tow away the car. The electric steering wheel lock cannot be disengaged and the car is not steerable. Jump starting, refer to page 194.< Do not tow-start vehicles with an automatic transmission. Only tow-start vehicles with a catalytic converter with the engine cold. It is better to jump start the engine, refer to page 194.< 1. Switch on the hazard warning flashers, comply with local regulations. 2. Switch on the ignition, refer to page 49. 3. Shift into 3rd gear. 4. Have the vehicle tow-started with the clutch pedal completely depressed and slowly release the clutch. After the engine starts, immediately depress the clutch pedal completely again. 5. Stop at a suitable location, remove the tow bar or rope and switch off the hazard warning flashers. 6. Have the vehicle checked." https://www.e90fanatics.com/pdf/E90_OwnersManual.pdf Last edited by PhaseP; 09-04-2019 at 08:50 PM.. |
09-04-2019, 10:47 PM | #12 |
488
Rep 1,309
My starter died a couple years back at my sister's workplace when she was borrowing it, in a big flat parking lot. Between the two of us we were able to get enough speed to start it up. Drove it to autozone, parked on a hill, and went in and bought a starter, roll started it, then drove home and installed it
09-05-2019, 04:08 PM | #13 | |
32
Rep 199
09-05-2019, 04:15 PM | #14 |
32
Rep 199
Yes, that's the plan for tomorrow (borrowing the scanner from my boss). If I get no readings (being it's not dedicated for BMW) then giong to have my brother do some exercise on Saturday.
09-05-2019, 05:12 PM | #15 |
3973
Rep 7,215
You can't start it with a dead (or no) battery because of a couple things - firstly, the CAS needs to give the DME permission to activate the injectors and coils. If that doesn't happen, the engine won't start even if the DME was powered somehow (by the alternator or something).
Naturally the fuel pump is electric, although that shouldn't stop you if there is residual pressure in the lines. And finally, without power you can't unlock the steering wheel so trying to push start an E90 with no battery is a really bad idea. I do like that if (when?) the starter ever failed, I won't be stranded, but if you have a totally completely dead battery - I have to believe there were warning signs ahead of time.. |
09-05-2019, 07:24 PM | #16 |
Rep 1
Just put you car at the ON position, 2e gear clutch in, you roll the car by being on a decline or someone pushing and when you reach like 7 mph and dump the clutch. Just remember to clutch in really quickly to make sure you don't stall the car.
09-23-2019, 06:44 AM | #17 |
32
Rep 199
Yes guys, thanks, I was able to push start it, took it to Bimmer clinic, they replaced the Starter, so it was the starter.
