09-02-2019, 02:03 PM | #1 |
7
Rep 55
Brake wear sensors and a couple of other bits...
Apologies if this has been previously asked. I am going to replace my disks and pads (OEM Blue M Sport Brembo's) and wanted to know if there is just one sensor fitted per axle or is it per wheel? I didnt want to but 4 if I only need 2. I could jack up the car and look but its raining at present and thought it might be an easy answer for someone who has done it themselves.
The car is a 2014 UK 330D with M Sport brakes and the 370F/345Rmm rotors as a dealer upgrade which I believe makes them the same as the M Performance brakes but without the drilled and slotted rotors, which I will fit because they look better. I have checked the Callipers and they are the Brembo's with the 370/380 markings on the rear. ( I know I should have checked for wear sensors at the same time....) I will likely stick with Brembo for the rotors (34106797603kt) but wanted opinions on pads? I do a lot of motorway driving with very little harsh braking but do like a nice drive on country roads every so often but no tracks. |
09-02-2019, 02:10 PM | #2 | |
809
Rep 1,597
09-03-2019, 07:29 AM | #4 |
7
Rep 55
Thanks for this, I understand that the sensors are more or less an on/off with the way it works (wears down a covering when the pads get too thin) but is it not a best practice to just swap them anyway given they are only about £10? I am happy to leave them as they havent tripped, just asking.
09-03-2019, 05:24 PM | #5 | |
NewFinishColumbia/detailer
604
Rep 2,096
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
09-06-2019, 08:37 AM | #6 | |
Modder of everything I own
147
Rep 491
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
