SOLVED: is your 6mt rough?
09-01-2019, 07:41 PM | #1 |
471
Rep 996
how rough is your 6mt when it comes to bucking when you get on/off gas, in normal driving situations?
whenever i let off the gas, its almost like the car is getting a slight kick in the rear, no matter how much i let off (releasing the gas pedal 1mm still gets the same feeling). my guess is that something is worn. could it be engine mounts/trans mounts? or a bad rear dif? FYI I solved this by putting in new motor mounts and transmission mounts. No more bucking Last edited by porsche959; 09-20-2019 at 08:37 AM.. |
09-01-2019, 07:54 PM | #3 |
471
Rep 996
09-01-2019, 09:22 PM | #4 |
Is it the shoes!?
3884
Rep 5,112
09-01-2019, 09:33 PM | #5 | |
1436
Rep 2,526
Drives: 2011 328i Wagon
I'd have a look at motor, trans, and diff mounts first. I would think anything worn in the driveshaft would cause vibrations. But maybe an issue with the dual-mass flywheel, could be a cause too if it isn't damping properly?
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
09-01-2019, 11:18 PM | #6 |
27
Rep 144
Tune perhaps? If stock I'd first check for any air leaks, dirty air filter or sensors, and reset adaptations. Basically the fuel prep system.
My 1st gear pretty smooth, but my 2nd gear grinds unless I engage it super slow. Killed a lot of the street driving experience and was saddened to read that this was normal. |
09-02-2019, 11:07 AM | #7 |
3973
Rep 7,215
Mine is smooth. No grinding either -150k, original clutch.
I don't think grinding gears is "normal"... |
AWDBooSTIn90148.50 |
09-02-2019, 11:12 AM | #9 |
2709
Rep 1,538
hahah, Ive described the exact same thing in an other thread. '' someone kick the car''
same issue here. Ive just got the car, and waiting to do oil change before looking further in that issue. |
09-02-2019, 11:32 AM | #10 | |
471
Rep 996
I’m not getting any grinding, just bucking. As in the car lurches forward. |
09-02-2019, 12:35 PM | #11 | |
2709
Rep 1,538
-Then I was pretty sure that was transmission related. -Then I thought about a missfire, but I don't have any code... Anyway, during my maintenance stuff, Ive noticed 2 things. - both center sparkplug were full of oil. Common problem on those n52. Ive cleaned the coils and plugs. - passenger side ground was broken. I fixed it with a 8gau wire. Didn't ride the car yet. |
09-08-2019, 08:02 AM | #12 | |
22
Rep 111
09-20-2019, 08:35 AM | #14 |
471
Rep 996
10-26-2019, 04:33 PM | #15 |
2709
Rep 1,538
I also figured out my ''kick in the transmission''
front drive shaft ubolts were shot. huge loose. I need to find a drive shaft now, rockauto and FCP euro don't carry them anymore... |
10-27-2019, 08:12 AM | #16 | |
17309
Rep 18,733
Contact Driveshaft Specialists of Texas, they'll probably have a fresh rebuilt shaft in stock or will rebuild yours. They are an excellent source for BMW driveshafts. http://www.driveshaftspecialist.com/...0html/BMW.html
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
oVeRdOsE.2708.50 |
10-27-2019, 08:14 AM | #17 | |
17309
Rep 18,733
TIA
10-27-2019, 01:57 PM | #18 | |
2709
Rep 1,538
thanks for the link ! |
10-28-2019, 08:44 AM | #20 | |
2709
Rep 1,538
While doing my transfer case oil change, Ive noticed that the shaft was loose. So it gives a ''kick'' when the rotation slows down then get back up. On the highway, it gives a smoother kick, but still there. no metal sound, since the metal parts are not touching yet, but its coming soon. Solutions : 1- get a new one @ xxxx $ 2- rebuilt it, according to internet this is a hard job getting those universal joint out. so you'll ending up with 4 hours job + parts, around 400-500$. 3- get a salvaged one. They should last 200 000km if they are greased up on a regular maintenance. 4- remove it. 5- leave it, it won't break so easily. I choose option 3, since its my beater, and here we got a tons of smashed E90 xdrive. On upull scrap yard the part is 30$ , and of course all yard I've called the transmission is the 1st thing that goes. On FB I got 3 prices, all 200$. The tranmission mount was fine, no crack. But I fill it with 3M windshield sealant anyway, aka bushing maker. |
10-29-2019, 09:41 AM | #22 |
2709
Rep 1,538
Just realize on my E91 I have a jobber front drive shaft while removing it !
it also got a grease port. I'll ditch the used OEM drive shaft, and rebuilt mine for sure. BUT ! What is the universal joint part # ? Ive looked on amazon, ebay, realoem and now I've send a email to Dorman. |
