Getting "Outside light failure" symbol... but all the lights seem to be working?
08-30-2019, 08:25 PM | #1 |
16
Rep 103
I had the funky looking lightbulb symbol pop up on me today in the driveway before getting underway. I examined the signals, the brakes, low and high beams, fog lights... all seem to be working. I also happen to have a Volvo that has had a "bulb position failure" message for 10+ years, even though every bulb is working... is this a common sensor fault to BMW as well, or is there some fancy bulb I'm overlooking (like the ones on the bottom of the doors that make the BMW hologram on the pavement?)
08-30-2019, 09:34 PM | #3 |
2697
Rep 4,031
Use "Check Control" to display the "CC-ID" number on your instrument cluster, and post it here if you do NOT have Bentley or other reference to lookup the definition of the CC-ID code.
Search "Check Control" in the Index of your Owner's Manual for the procedure to display the code. If you have the Bulb Fail Warning Light on the Instrument Cluster, you DO have a CC-ID code that you can display, which will identify which bulb or type of bulb has the issue. You should also see a "!" in a yellow triangle to the right of the Gear Selector display at lower-center of Instrument Cluster which means there is a CC-ID code saved. Be aware that you MAY have a situation where the bulb fail module warning lights even though ALL bulbs are lighting, but you ALSO may have the situation where ONE of the two tail lights on one side is out and you don't realize it, or a license tag light is out, etc. George |
09-01-2019, 06:38 AM | #4 | |
17309
Rep 18,733
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
Tags |
light bulb |
