E90 m3 steering rack swap impressions
08-29-2019, 04:03 PM | #1 |
471
Rep 996
Installed m3 rack. Took 4-5 hrs. Hardest part was getting the steering spindle removed/reattached.
First impressions: *I am on the fence on whether this was worth the work or not. I did this in a public parking garage on jacks, and my entire body is fcking sore, one day later. It’s a noticeable mod but I am not blown away by it. That said, I’m happy I did it...but in hindsight I am 50/50 on if I would do it again. My view may change once I hit the twisties in upstate NY. I’ve only driven about 50 miles total around nyc and NJ. For reference, the only other suspension mod I’ve done (besides full oem non sport suspension refresh) is an e93 m3 front sway + bushings - which I highly recommend. *steering effort requires about 50% more strength versus stock, at stand still (see vid). At speed it’s about 30% harder. YMMV tho as my stock rack was fairly stiff. *overall driving feel comes off as stiffer. Could be new tie rods (stock 325 inner and outer tie rods) or new alignment. I feel more bumps on the road. *Steering rack cost $380 used, I installed myself over 4-5 hours. Alignment was free (Firestone lifetime) and definitely needed ASAP. Not safe to drive without alignment. *Make sure to use a full L of power steering fluid. It will screech like death when even 10% low on fluid. *lock to lock steering wheel movement has been reduced. Went from about 1.5 left and right rotation to about 1.25z |
08-29-2019, 05:50 PM | #3 |
471
Rep 996
09-02-2019, 11:20 AM | #4 |
2188
Rep 5,002
09-02-2019, 02:21 PM | #5 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
I probably wouldn't consider this upgrade unless my rack went bad. I'm basing this on the fact that a rack is expensive to begin with and your post.
AWDBooSTIn90148.50 |
09-02-2019, 05:52 PM | #6 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Such an interesting place to do that! Good job, though!
I have considered doing this, probably if my stock rack went to shit. However, the E90 stock steering rack is already quite good for what it is. I think these swaps like putting the Z3 rack in E30/E34/E36 etc is more popular just because there is such a larger difference from stock, in that case. Regardless, really interesting! Seems like you got a good deal on it too. I have seen E9x M3 steering racks go for much more!
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
09-02-2019, 05:56 PM | #7 |
945
Rep 1,507
Also, cool choice of steering wheel. I was just thinking about getting a new one myself. I found a guy in Ukraine who refurbishes the sport steering wheels with the flat bottom, that accept the M-Sport airbag. They seem affordable, however I would like something a bit more different. Aftermarket, but OEM+ looking. Are you nervous not having a steering wheel airbag? I assume you don't have a harness or anything.
09-02-2019, 10:07 PM | #8 | |
471
Rep 996
thanks. i like the feel of the steering wheel much better versus the stock, thin non-sport wheel. the 350mm size also helps the car feel much more sporty. hate the ricer momo horn, but its really well made (nice contact points, metal) versus any aftermarket BMW momo horns (shitty contact points on all options ive tried), so it must stay. dont really care about the airbag. i probably should, but dont. |
09-02-2019, 10:10 PM | #9 |
471
Rep 996
update - so its been a few days, and a couple hundred miles on twisties + city roads. getting used to the increased effort required to drive it. did not even notice it today, so maybe im getting stronger.
cant say if its better or worse on the twisties, but surprisingly it makes parallel parking in nyc much easier. u turns are much more efficient as well. |
