08-27-2019, 02:01 AM | #1 |
Rep 75
how to get maximum camber
How is the way to get more camber without putting plates or putting F80 Lca? (I don't want wheel deflection towards the fin)
I do not want annoying noises, I prefer to have less camber, but I would like to increase it more than 0.5 degrees of the powerflex silentblocks |
08-27-2019, 07:48 AM | #2 |
432
Rep 785
Assuming you don't want camber plates,
There are OEM hub replacements that add 0.5 deg https://f30.bimmerpost.com/forums/sh....php?t=1643061 Also could replace the stock control arm with the m3/m4 control arm which adds 0.5 if you are rwd. XDrive not compatible |
08-27-2019, 07:59 AM | #3 | |
Rep 75
but the arms M3, join the wheel with the fin right? and there is a possibility of friction. |
08-27-2019, 09:59 AM | #4 | |
432
Rep 785
https://f30.bimmerpost.com/forums/sh....php?t=1090804 Rwd only, no xDrive cars. Can't tell what you have Last edited by Jvac; 08-27-2019 at 03:41 PM.. |
08-28-2019, 07:09 AM | #6 |
Car Hypochondriac
335
Rep 901
Drives: 2014 335i M-Sport Estoril Blue
Check out the kmac camber bushings. Most people seem to get close to -2 degrees.
08-28-2019, 12:27 PM | #8 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
You can order them direct from KMAC in Australia. That's what some of us in the USA have done.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
08-28-2019, 06:45 PM | #10 | |
Rep 27
09-03-2019, 04:12 AM | #11 |
95
Rep 189
Just installed these prototype Millway camber plates on my F31 X-Drive... they use the factory plastic bearings just as their standard camber plates, but these prototypes added polyurethane bushings to address the chatter produced by typical camber plates.
Bearing (pun intended) in mind that I have zero experience with camber plates, my initial impression is that there is very faint chatter that can be heard at low speed, but at speeds over 15mph - nothing. More to follow in another post: https://f30.bimmerpost.com/forums/sh...7&postcount=22 Last edited by shawrf1; 09-03-2019 at 04:55 AM.. |
FaRKle!4017.00 |
10-08-2019, 02:24 PM | #12 | |
Rep 75
after this time, how are the noises going? |
