F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Lower BMW 328d x-drive?
GetBMWParts
      08-26-2019, 01:48 PM   #1
Thormus
Drives: 2016 Bmw 328d x-drive m sport
Just bought a 2016 328d X-drive (M Sport) with standard suspension. Wanting to put 19'' wheels and drop some of the wheel gap. I use this car as a daily driver. I live in Idaho so we can have bad winters. Whats the best option to reduce wheel gap, maintain enough clearance for speed bumps / snow and not ruin the ride?
I know this has been asked a few times on here and I have read a lot. Are KW Street Comforts the best option? Can shocks / springs compare?
      08-26-2019, 02:30 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Unless by some miracle you don't get potholes in Idaho you should reconsider 19s for winter use.
      08-26-2019, 03:51 PM   #3
Thormus
We do have potholes. I would have 18's in reserve for winter.
      08-26-2019, 05:17 PM   #4
Billfitz
Billfitz's Avatar
Smart move.
      09-02-2019, 09:34 PM   #5
Thormus
anyone have thoughts?
      09-02-2019, 10:04 PM   #6
johnung
Drives: 2015 BMW 335i x-Drive Auto
Dropped my xdrive and reduced the reverse rake by installing Eibach spring kit (-06 in the part number) Drops the front 0.8" and rear 0.6". Only 10% stiffer so doesn't wreck the ride.
You can also reduce the appearance of wheel gap by switching to a higher sidewall tire size. In 18" wheels with stock 225/45-18 size that could mean going to 235/45-18 or 245/45-18. You'll have to do the research for 19" sizes.
      09-05-2019, 04:10 PM   #7
Thormus
Ok I think I've decided on eibach springs and bilstein B8's. I think I want to go with the RWD springs as they are a lower drop. I am having trouble figuring out part numbers. Do I need to buy these things separately or is there a B12 kit I can buy?
      09-05-2019, 04:19 PM   #8
johnung
Eibach spring kits have a -06 in the middle of the part number for the xdrive version and a -05 for the rwd version. I've seen a Bilstein/Eibach kit but don't recall the details.
      09-05-2019, 05:02 PM   #9
johnung
The Eibach springs xdrive part number is
E10-20-031-06-22, ~$291
I know the rwd part number -05 but I keep finding this part number E10-20-031-02-22
Not sure the difference between -05 and -02 part numbers. Don't have time to look right now
      09-05-2019, 06:12 PM   #10
BUFFLARS12
25
Drives: 2013 AW f30 328i xdrive M Spor
Isn’t the first number (235/245) the width?
The second number is the aspect ratio which would be a “taller” tire
      09-05-2019, 06:17 PM   #11
FaRKle!
4017
Drives: 328d Wagon, M2 Comp, i4 eD35
That's because E10-20-031-06-22 and E10-20-031-05-22 are both 335/340 xDrive kits. E10-20-031-02-22 is the only kit they recommend for 335/340 RWD. The xDrive kits' front and rear springs are stiffer than the RWD kit.
Use the links in my sig to see kit/springs details.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
johnung4528.00
      09-05-2019, 08:56 PM   #12
Thormus
328 xdrive requires different than 335? Does gas vs diesel matter?
      09-06-2019, 06:49 AM   #13
larrylam646
larrylam646's Avatar
371
Drives: 2020 M340i xDrive
Eibach does not list a Pro Kit for the 2016 328dX but Eibach does have a listing for an F30 320dX (which uses the same N47D20C engine).
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold
f30post
