2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Tire sizes (thickness?) Front versus Rear?
      08-26-2019, 10:05 AM   #1
clone000
10
Drives: F10 | N20
Hi Guys,
I have rims with 35 in the front and 30 in the rear... For curbing it is kinda crazy, wanted thicker tires.
I guess with F10s, the tires should be thicker in the front, i.e. 35 and 30 in the rear,
I guess if i want 245 / 45 / R20 in the front, I should get 275/40/R20 in the rear...
But is 45 too thick / high? I just did not want to hit pot holes, and i wanted to fill up the wheel well.
Thoughts?
2013 M Sport 528i
- HM Style Carbon Fiber Front Lip | Dual Slat Gloss Grill w/ M colors |H&R Front / Rear Sways |Downpipe (Catless) | Afe Intake
      08-26-2019, 10:20 AM   #2
wcr3d
461
Drives: 2013 535i XDrive M Sport
It's best to avoid pot holes.
Just so you know, the taller the rim, the less cushion( thickness as you are calling it).
From what you are asking you should go in the other size direction and lower the car to fill the wheel well.
Also you do not have to run staggered sizes.
      08-26-2019, 10:41 AM   #3
clone000
10
Drives: F10 | N20
Thanks car will be lowered...
I Saw another thread where higher ratio might rub the knuckle?
Can i go with 45 ratio in the front?
2013 M Sport 528i
      08-26-2019, 06:20 PM   #4
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
No, but you can go one step up, to 245/40/20.
      08-26-2019, 10:40 PM   #5
clone000
10
Drives: F10 | N20
Thanks, so 245 / 40 in the front and 285 / 35 in the rear?
That should look better than 30 in the rear, its too thin.
2013 M Sport 528i
      08-27-2019, 03:12 AM   #6
remmib
remmib's Avatar
Norway
1569
Yes
5post
