N54 Part Out
08-25-2019, 08:16 PM | #1 |
Professional Hack
96
Rep 379
N54 Part Out
Catless DPs - SOLD GPlus 5" Intercooler - SOLD Coolerworx (CAE-style) self centering shifter - SOLD OE Turbos (SOLD Coils (Delphi GN10328) - SOLD Spark Plugs (NGK 95770 ILZKBR7B8DG) - SOLD ARM Charge Pipe (for OE DVs) - SOLD BMS Oil Filter Cap - SOLD Injectors Index 11 - SOLD HPFP 20,000 miles - SOLD Alternator - SOLD 6MT w/ 105,000 miles - $400 (Regional Pickup Only - I will meet up anywhere within ~2 hrs. Higher offer = larger meet up radius ) Engine Block 105,000 miles - $450. Blackstone Oil Test Results do not indicate any issues. However, the engine has not been opened up for inspection. (Also Regional Pickup Only) Intake Manifold - $85 Throttle Body - $30 Mishimoto Oil Cooler Line Adapter - $40 OE Airbox and Filter $60 Vacuum Canisters - $50 AC Condenser - $60 AC Compressor - $50 Water Pump - $100 Thermostat - $35 Pair of Boost Solenoids - $60 O2 Sensors (4) - $30 each BW oil sensor adapter (distribution block) - $50 ARM (DV) charge pipe - $90 shipped ARM Dual Cone Intake - $65 shipped ------- ADDED 1/2/2020 Power Steering Pump - $50 -------- Added 1/17/2020 ARM (DV) charge pipe - $90 shipped ARM Dual Cone Intake - $65 shipped Price Drop: Engine Block 105,000 miles - [s]$600[/s] $450 6MT 105,000 miles [s]$500[/s] $400 Engine + Trans package deal - $720 Anything not listed, feel free to ask.
MCS 1WNR Dampers | Ground Control Camber Plates | E90 M3 front control arms| E90 M3 front tension arm w/ Turner monoball bearings | E90 M3 Steering rack conversion | SPL Adjustable Outer Tie Rod Ends | M3 Rear Camber Arms | SPL Adjustable Rear Toe Arms | M3 Front Caliper Conversion | 275/35/18 Toyo RA1s | 18x9.5ET22 Apex EC-7’s | mFactory LSD | AIM EVO4S with GS Dash | New for 2020: LS1 Swap!
08-26-2019, 01:00 PM | #4 |
57
Rep 156
PM'd
08-26-2019, 02:22 PM | #5 |
49
Rep 392
what's up with the turbo's? OEM replace less than 3000 miles ago. something wrong with the previous turbo's? were they purchased from a reputable place, any issues when you were using them? thanks,
08-26-2019, 06:13 PM | #6 |
Professional Hack
96
Rep 379
The first set of turbos' waste gates were shot and giving me 30FF codes, so I had the turbos replaced under an aftermarket warranty by Bimmers R Us in St. Louis and I had no problems with them.
I'm parting the car out because I'm a maniac doing an LS swap.
rusty_sojah49.00 |
08-26-2019, 09:04 PM | #7 |
57
Rep 156
08-27-2019, 08:46 AM | #10 |
Professional Hack
96
Rep 379
Intercooler is OE clip connections.
Spark plugs & coils have 1 hour of track time on them.
08-27-2019, 11:30 AM | #13 |
Professional Hack
96
Rep 379
about 50 miles on the spark plugs. it's a track only car.
08-28-2019, 09:37 AM | #14 |
Professional Hack
96
Rep 379
Shifter is still available!
08-28-2019, 10:16 PM | #15 |
57
Rep 156
08-28-2019, 11:11 PM | #16 |
Rep 68
Drives: 2010 e92 335i
Potentially interested in injectors, plugs, an turbos. PM me
09-03-2019, 11:07 AM | #19 |
Professional Hack
96
Rep 379
09-04-2019, 09:16 PM | #21 |
Professional Hack
96
Rep 379
Injectors are index 11. Asking $350
09-05-2019, 09:06 AM | #22 |
59
Rep 469
Drives: 2008 BMW 135i 6MT
Interested in Turbos, sent a PM!
2008 TSM 135i N54
