08-25-2019, 03:03 PM | #1 |
Rep 13
Radar Detector Issue
Own a fully loaded G20 XDrive. I have a valentine one radar detector and I also have it mounted on a bracket thatJust below rear view mirror. The problem is the radar detectors interfering with all the radar sensors on the vehicle specifically the radar cruise control..Has anyone had this issue and is there a workaround? The K40.360 is supposed to work but don't want to permanently install.
08-25-2019, 03:21 PM | #2 | |
1588
Rep 4,551
BMW radar sensors are much higher frequency than your V1 is looking for. I believe BMW uses 76-77Ghz.
2023 840GC | 2021 740i | 2019 X3
08-25-2019, 04:26 PM | #3 | |
Rep 13
Thanks! |
08-25-2019, 04:35 PM | #4 | ||
1588
Rep 4,551
Or maybe you can find the fuse powering it, but I'd be concerned about powering off other devices.
08-25-2019, 04:39 PM | #5 |
236
Rep 1,037
I would just disable laser, by the time you're picking it up you've already been nailed
M340i: Arctic White, 790M wheels, Cognac interior, Aluminum Tetragon trim - Totaled
08-26-2019, 06:16 AM | #6 |
Rep 13
We own Laser Diffusers so I'll get them transferred and valentine one. I suspect that all of the radar manufacturers are going to
update software to accommodate all of the safety systems, |
09-20-2019, 05:58 PM | #7 |
42
Rep 131
I have the same issue. I kind of like the gesture control but suspect I might cover the emitter on longer road trips.
Between Waze and the V1 have not been pulled over for several years (though my V1 is likely getting old in the tooth). |
12-27-2019, 08:47 PM | #8 |
1253
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
Have this problem as well. Only happens at night though.... I just gave up and turned off laser on the valentine one
