Stripped screw while replacing HPFP
08-24-2019, 07:26 PM | #1 |
Rep 25
So I stripped a screw on the hpfp while attempting to replace it. Should I just take it to the shop and let them handle it or does anyone know of any way I can save myself $300 and just finish this DIY job that I started? Here's a pic of the screw that got stripped.
View post on imgur.com |
08-24-2019, 07:38 PM | #2 |
Is it the shoes!?
3884
Rep 5,112
When you mean you stripped it, you mean the Allen head no longer fits right? One solution is to take a slightly larger Allen head and jam it in. The other solution is to try and fit some small vice grips to take it out. The final solution would be to drill or use an easy-out, but the tight quarters would make it difficult.
Since you're replacing it, you might be able to get at it from the side and drill the head away. You'll need a new bolt regardless. |
08-24-2019, 09:07 PM | #3 | |
Rep 25
08-24-2019, 09:53 PM | #4 |
Is it the shoes!?
3884
Rep 5,112
