08-22-2019, 08:13 PM | #1 |
Rep 17
xDrive Coilovers
Hi all
First post for me, but I've been looking through the suspension forums for a while now. I was wondering if anyone provide some insight into picking the right coilover. I have a 340i xDrive so I'm limited in my selection. A little bit about my driving: The 340i is my daily driver. I just got into HPDE due to a recent move, and I can see myself attending 5 HPDE a year since there's 2 repaved HPDE tracks nearby. I'll also probably participate in some autocrossing. As for local commuting, the roads in Michigan are bad, but tolerable. There are the occasional ninja potholes where my current suspension will bottom out. I also walk to work so I don't drive that much each year. My thoughts on my stock EDC suspension are that its comfortable, but I could easily drive with a stiffer setup. What I'm looking for: I'd like to invest into something that can handle the track well, and exceeds my skill level as a novice and intermediate driver. I obviously won't be getting into wheel-to-wheel racing, but I do intend to improve my skill and lap times whenever I am at an event. I may participate in some solo time attack events (e.g. autocross), but that'd be about it. The coilover I'm most interested in is the KW V3. I've seen some debate between the Bilstein B16s and KW V3s, mostly centered around subjective stiffness, and linear vs progressive springs. Does it really make a perceivable difference for a novice/intermediate driver? I'm assuming I could just switch out the stock springs with Swift springs. Lastly, for those with Bilstein B16 and KW V3 coilovers, did you ever feel like you needed something better at HPDE? I'd like to purchase something that I won't be selling off in 1-2 years because they are a limiting factor (that's the impression I got from coilovers like BC Racing). I'm also worried that the sellers market for xDrive suspension components is limited. I know this is all relative, which has been the troubling part. On the F80 forums, KW V3s seem to be the entry coilover, while TC Kline, AST and AC Schnitzers seem to be the norm. I can't afford any of those... |
08-23-2019, 09:31 AM | #2 |
120
Rep 410
Look into the MSS Kit (Street or Race) as it might be a good compromise for your needs as it will improve the daily and the track experience > Win - Win
https://mss.company/ If after years of experience you grow out of the suspension set up (after doing control arms etc.) then maybe upgrading the adaptive to Bilsteins would do the trick (or Oehlins if you can get by without adaptive) |
08-23-2019, 11:15 AM | #3 | |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Your first requirement means that you want a suspension that has smoothness, and composure. You want a coherent feeling vehicle that can handle the various road features experienced in daily driving. Your second requirement means you want a suspension that has excellent control, and that will help improve grip over what you have currently. It has to control quick body motions as well as be able to keep composure over curbing/rumble strips so you can use all the track. Lots of "stiff" setups with overdamped compression and/or rebound run into trouble when going over those features on the track. For example when I had EDC with Shockware the front compression was overdamped, so if I hit curbing on the inside apex of a corner it'd bounce me out. Beware any mfg that won't provide you with the data to do your homework with. There are some really sloppy companies out there like Bilstein, who use the same springs/damper/coilover for a lightweight 228i as they do a heavy 340i GT. This is one of the most "trusting" customer bases that doesn't demand mfgs "prove it" before buying, and therefore companies can get away with a lot.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
08-23-2019, 11:18 PM | #4 |
Rep 17
Thanks guys. Do either of you have suggestions for xDrive coilovers, or know of manufacturers that are more likely to modify their RWD setup for AWD?
Based on another thread (below), it seems to me that the front perches sit higher on xDrives. Is this a result of the front axles shifting the coilover position out laterally? If so, would the solution be a shorter springs and a higher perch? https://f30.bimmerpost.com/forums/sh....php?t=1614674 |
08-24-2019, 01:31 PM | #5 |
993
Rep 1,934
KWs will fit even if they are for RWD. Just use xdrive endlinks. There have been a couple members here who have fitted them fine with that in mind. BC as well.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
08-24-2019, 11:07 PM | #6 |
479
Rep 797
I have the v3s and they're pretty good. Handling wise they do well to expose the other glaring weaknesses of the chassis. The ride on the street is ok but certainly on the rough side. Your passengers won't exactly complain but they are maybe thinking about it. They are great on the highway and I'm at about 25k daily miles on them and still all good for the time being.
I run the bump full soft up front with the rebound around half way just where it doesn't feel bouncy. The rear about 3/4 stiff and it rotates a bit and is very predictable with the pedal down as awd usually is. Sway bars and a bushing kit kind of have to be done, it's a still a very floppy unconstrained car just now with stiff springs and good shocks. I had the b16s and couldn't get the front low enough. They were stiffer and I'd say we're better build quality than the kws. No rebound adjustment which is actually very nice to have. I didn't want to spend 3 or 4k but wonder what those options would be like for a DD. At 36k miles my brakes are nearing the end ... I wouldn't track with the grey msport brakes unless they are newer. They do kinda suck, "lack feel and have no initial bite". I think this car is just too heavy and sloppy to track at all. Last edited by B58 parts; 08-24-2019 at 11:15 PM.. |
08-26-2019, 10:28 AM | #7 | |
Rep 17
I've been looking around at other coilovers now, such as the TC Kline and MCS 2WNR. Any thoughts on buying V3s and switching to swift springs? Or are the dampers just not on the same performance level?
Its hard for me to gauge what is adequate still. I agree with having to only buy one set of coilovers, as opposed to repeatedly buying/selling marginally better products. Would the benefits of a TCKR DA or MCS 2WNR be appreciated by a novice driver? Quote:
08-26-2019, 12:41 PM | #8 |
4017
Rep 3,540
Would you be interested in a bespoke tuned suspension setup that was priced in the same range ($2-3k) as the B16 and V3s? If so, I'd go with a Fat Cat Motorsports stage 2 build.
08-26-2019, 12:50 PM | #9 | ||
148
Rep 205
Drives: 14 F30 335i xDrive
I have KW V3 on my car and I'm very happy with them. The dual adjustment is very handy to dial in the suspension according to how you want it and use. I track my car several times a year. I've found them to be comfortable on the street, yet fairly firm for the track. If you're hardcore at the track, they may not be enough. You should be able to upgrade to Swift springs. I haven't really heard of it on f series. There may be people that have done it. I've been contemplating it as well. It was common on the E9x series. However, if MCS has a set that works with xDrive, they're in another level of shock/strut design. More high end and Motorsport derived. Having had a fair amount of seat time in this car, I thing it's a blast on the track. Few cars can be so great all year in all types of weather, and still blast it on the track. I can keep up with M cars, mustangs and other cars that my 335i xDrive is not thought to be in the same league as. Oh, and brakes are strong. I only have the 340 grey calipers. If your brakes don't feel strong on the track, it may be your pad compound and/or not enough cooling. Bite on the street is definitely a pad compound thing. |
08-26-2019, 05:58 PM | #10 |
479
Rep 797
I haven't tracked the car, it feels too sloppy to me still and wouldn't stack up all that well against other cars I've ran in the past.
More hp for the straight but that's it, so many lighter cars will be all over me in the braking zones, and mid corner my side mirror is touching the ground. I do plan to I just want to be more confident in it first. And I gotta buy a new friggin helmet. The v3s are a great step forward but the rest of the stock chassis just isn't all there. It doesn't feel point and shoot. But it does have a ton of grip and is a blast when building momentum. |
08-26-2019, 06:25 PM | #11 |
372
Rep 1,425
Check out the KW DDC option, if you're not familiar. I have them on my F31, but I don't track and have it way too low to truly appreciate the capabilities. From my understanding, it's similar to the KW V3. However, it connects directly to the EDC controls. So, it will stiffen the dampers from within the cabin (same rocker you're already using - Comfort, Sport, Sport+). Height is adjustable on the outside. Not the best track option, but a solid daily driver/track combo.
https://www.kwsuspensions.net/products/coilovers/ddc
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
08-26-2019, 07:22 PM | #12 | |
5886
Rep 10,256
08-26-2019, 10:37 PM | #13 | |||
Rep 17
I called KW in the meantime. I mentioned I was looking into the V3 for my daily and intended to use them for occasional track use. The tech suggested KW CS's instead due to accelerated degradation for the V3 from autocross. Then they realized they didn't sell any for xDrive. At this point I asked how many track days per year is tolerable for the V3. Apparently 0. The V3 is a street performance coilover only. Kind of bummed. I was under the impression the construct was similar to the clubsports (aside from valving and spring rates). Make also me wonder how much life my OEM suspension really has left. They already have 53k miles on them. I emailed TC Kline and AST to see if their suspensions work with xDrive. The AST 5100 looks more promising to me with their modular design. I guess I'll look at the Bilstein Clubsports at this point as well. Anyone have any experience with these? The 340i felt pretty capable to me during the HPDE. My biggest gripe was the steering felt vague. I was hoping some coils and maybe new bushings would help with. |
08-26-2019, 10:53 PM | #14 |
993
Rep 1,934
I'm surprised no one has mentioned Fortune Auto 500s yet. They are well revered in the JDM world, and are a bit cheaper than KW street comfort. You can customize them as well. Camber plates and swift springs are standard with them. They have them in varying x-adjustable shocks as well as 100% race ready inserts. I would give them a look.
https://shop-fortune-auto.com/produc...ries-coilovers
08-26-2019, 10:56 PM | #15 |
148
Rep 205
From what I've researched, the design of the KW club sport is very different from the V3. They are designed to last longer in the auto-sport area and perform at a higher level. However, just because the V3 go on track doesn't mean they'll fall apart. I think the potholes around the NYC area will do far more damage than half a dozen track weekends a year. Plus I've spoken to other people who have them on their street cars and also tracked the V3 occasionally. They loved the V3 for its all around performance. Personally, I'm not looking to I get 5-10 years out of them. More like 2-3 and I'd be happy. Living where I do most shocks don't last longer than that with no track time. Better part of a year and they still ride great so far.
Comes down to budget and desired use. If you have the budget and the patience to wait, some of the higher end companies will build a set for the xDrive and your desired us. I choose the V3 because they were the best all around option without having to wait months and at a reasonable price. Also I don't like the ride of the high pressure Bilstein shocks (they were one of the only other decent choices without paying twice as much). Not to mention there really just aren't as many xDrive options at the moment. |
08-26-2019, 11:00 PM | #16 |
993
Rep 1,934
The clubsports also have an external reservoir to keep the shock oil temps down. Else those seals will go quick. If you are really adamant, BC makes one, but never did for the f30. They should be able to custom make you a set. Same with Fortune Auto if you give them a call.
This is also the first I've heard that the V3 can't be taken on the track. Why would you need 2 ways adjustable shocks just for the street???
08-26-2019, 11:04 PM | #17 | |
148
Rep 205
DrPancakes8.00 |
08-26-2019, 11:11 PM | #18 | ||
993
Rep 1,934
08-26-2019, 11:57 PM | #19 | ||
4017
Rep 3,540
Bilsteins are well built with good materials and from the get go have a digressive piston. You want a digressive damping curve to avoid having too high compression/rebound forces at high speed. Lots of companies advertise "digressive piston" or "linear piston" because it "sounds impressive" and customers don't know what it actually means. There isn't really any reason to go with linear pistons. One thing you will want to do is your homework on spring rates and frequencies. I think targeting a 1.5-1.6Hz front (and appropriate rear frequency to achieve fast settling/flat ride) is probably a good choice. Of course if you want to go more "racecar" you can go higher. Check out Shaikh's youtube channel (Suspension Truth) for a wealth of information on suspensions. With some of the options you've been talking about, it seems like an FCM stage 3 build might even be in your budget... Quote:
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 08-27-2019 at 12:06 AM.. |
08-27-2019, 11:12 AM | #20 | |||
993
Rep 1,934
DrPancakes8.00 |
08-27-2019, 01:12 PM | #21 | |||
Rep 17
I contacted fortune auto. Doesn't sound like they're going to make an F30 xDrive system anytime soon. TC Kline might be able to make a custom set. Guess I'll be doing more research before I commit to anything soon. |
08-27-2019, 02:48 PM | #22 | |
4017
Rep 3,540
Some "pre-work" that you'd normally have to do (like getting motion ratios and measurements) are already done for you from my and other F8x/F2x vehicles Shaikh's done. For vehicle weight and distribution, those figures are published (and part of his info form asks how much driver weight to expect and if there's typically more people/load that needs to be considered too).
DrPancakes8.00 |
