Bimmerpost
4 Series
Technical Topics Wheels and Tires 19" Forgestar F14 Bronze on Portimao Blue M340i
      08-22-2019, 07:39 PM   #1
raptorapture
raptorapture's Avatar
Drives: 2020 m340i
2020 M340i  [0.00]
Big thanks to Kevin **********s and Forgestar Wheels for going back and forth with me regarding fitment and tires.
---Specs---
Front Wheels- 19x8.5 +25 (Semi Deep Concave)
Rear Wheels- 19x9.5 +30 (Deep Concave)
Front Tires - Michelin Pilot Sport 4S 245/40/19
Rear Tires - Michelin Pilot Sport 4S 265/35/19
Rears have a bit more room to go wider but would have to adjust the offset since +30 is showing a little poke, front fitment is tight on this one with +25.
Rear wheel and tire profile.
Front fitment.
Waiting for Dinan to wrap up their R&D on the suspension goodies so I can drop it a hair to eliminate some of the gap.
      08-22-2019, 08:13 PM   #2
stratatak7
stratatak7's Avatar
Drives: 2016 228i xDrive M-Sport
Beautiful car! The F14's look so good.
      10-11-2019, 06:31 PM   #3
JDUNITNOW
JDUNITNOW's Avatar
Drives: BMW 335I, 750li, X5 G80
How wide could you go with the rest? Do you know what the offset would change to?
      10-11-2019, 10:09 PM   #4
raptorapture
Drives: 2020 m340i
2020 M340i  [0.00]
Rears you could go wider, I have to get the car up in the air and check it out to see how much wider but i dont think 10" wide wheels with 275's would be an issue other than when you pass 265 you start getting into hydroplane city.. Fronts are probably about perfect there in my opinion.
      10-11-2019, 10:13 PM   #5
raptorapture
Drives: 2020 m340i
2020 M340i  [0.00]
Couple more images after a bath.
      10-17-2019, 09:42 PM   #6
JDUNITNOW
JDUNITNOW's Avatar
They really look nice. I want 20's but the 30 and 25 profile scares me. I have a 7 with 22's and bent my wheel on a pot hole. Also I do not want to compromise ride.
I was thinking a 19 x 9 with a 245 and a 19x10 with a 275 or 285 rear. Not sure if this will fit.
      10-18-2019, 09:50 AM   #7
BarryB
BarryB's Avatar
Drives: 30Jahre M5 plus a few more M's
Those look great. Can't wait to see mine with the same tire sizes (different wheels)
Current non-BMW's
20 Jeep Grand Cherokee
03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)
15 Turbo S (Kobb tune and Kline exhaust)
      02-13-2020, 09:58 AM   #8
Denys_BMW
Ukraine
30
Drives: M340i xDrive
---Specs---
[IMG]
View post on imgur.com
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
Front fitment.
According to tyre and wheel calculator you have wheel outside diameter at front 679mm (26.7") and at rear 669mm (26.3") so rear wheel has 10 mm (1.5%) smaller outside diameter then front wheel. As I know it's not good for xDrive transfer case. As I see you have RWD car, you don't have this problem. How do you think is it necessary to use 235/40 + 265/35 tyres size on xDrive car with the same wheels?
      02-13-2020, 10:49 AM   #9
purpl3ish
purpl3ish's Avatar
Drives: 2023 G80 Velvet Orchid M3
love these wheels had it on my E93 super deep concave front and back. look great on the car!
2020 G20 Twilight Purple M340i xDrive,
2017 F80 30 Jahre, 2011 E92 335i xDrive///M3, 2012 E93 ///M3 -- Retired
      02-17-2020, 06:49 AM   #10
mischiefbenz
Drives: 2017 F80
---Specs---
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
Front fitment.
I believe as long as the rolling diameter is within 3% on an x drive car you're ok.
      02-19-2020, 12:30 AM   #11
Denys_BMW
Ukraine
30
Originally Posted by mischiefbenz View Post
I believe as long as the rolling diameter is within 3% on an xs rove car you're ok.
What does "xs" mean? If you mean xDrive then the difference between the diameter of the wheels on the front and rear axles should be no more than 1%.
      03-01-2020, 04:15 PM   #12
NoTanks52
112
Drives: M340i
If one wants to go super deep concave on both front and rear with the F14, and the front in 19'' only shows available in that profile at 19x9.5, can we go that high in the front?
g20
