08-21-2019, 02:19 PM | #1 |
278
Rep 456
Wheel Specifications 791M, 792M, 793M
Hi Everyone,
Can anyone verify the wheel specifications for the 19" wheels mentioned below for 791M; 792M; 793M wheels with M-Performance Brakes or with the ZTK package? From what I know our BMW G20s have a bolt pattern of 5X112, but what about other specifications like: Center Bore? Offset? Wheel Width? Stagger i believe is 8 in front and 8.5 in Rear? |
08-22-2019, 10:24 AM | #3 |
278
Rep 456
I believe this is true in Canada, the package is called 'M Enhanced Track Package' code: ZGW
With Fall season approaching, definitely need to look at Tires and Rim combinations, especially for those including myself with the Summer Tires. |
08-22-2019, 12:06 PM | #4 |
1568
Rep 29,202
They're all the same size. Front 19x8 ET27 and rear 19x8.5 ET40.
08-22-2019, 08:25 PM | #5 |
51
Rep 54
Center bore is 66.6mm
08-26-2019, 12:37 PM | #6 |
47
Rep 82
TireRack recently added the G20 to their wheel database. They now list regular and winter wheel/tire combos, 18 and 19. If buying elsewhere, you could use their suggested wheel sizes as a starting point for specs.
I emailed their customer support regarding ZTK and was told that their listed 19's would work, but 18's will not. I'm planning on ordering a winter set from them soon. |
