Shredding serpentine belts..
08-20-2019, 08:17 PM | #1 |
Rep 41
Hey guys. So far this year I've went through 4 belts. Starting to really worry me because not trying to have the next belt go through the front main seal.
Two of the times that the belt shredded, much if the belt was wrapped up around the alternator pulley. I have replaced the tensioner, both idler pulleys and have changed the oil filter housing gasket because I thought that was leaking on it. Also the power steering pump has had a few loose bolts, I've tightened those down and still having issues. At this point I have no idea what to do. All pulleys seem to function properly. None feel loose. When watching the belt while car is running, everything looks good. Just sorta stuck at this point. Anybody have any suggestions? |
08-20-2019, 11:07 PM | #5 |
1911
Rep 13,103
08-21-2019, 01:30 PM | #6 |
Rep 41
08-27-2019, 09:44 PM | #7 |
Rep 41
Is it normal for a tensioner to have a slight wobble on it? The past 2 I have bought have both had a slight wobble. The top wheel on the tensioner kinda moves back and forth slightly while spinning. Is it possible that this is the problem? Everything else has been inspected thoroughly and that is the only thing I can find.
08-31-2019, 10:46 AM | #9 |
Rep 41
09-02-2019, 01:42 AM | #11 |
Rep 41
09-02-2019, 03:07 AM | #12 | |
10
Rep 43
09-03-2019, 01:54 PM | #13 | |
204
Rep 525
