08-18-2008, 10:01 AM | #1 |
73
Rep 610
Racing Fuel?
Out of curiosity, has anyone put racing fuel in their M3 other than what I have read on this post:
http://www.m3post.com/forums/showthread.php?t=164325 any dangers with putting 110 octane in?
EDC.....viagra for your car
08-18-2008, 10:17 AM | #2 |
26
Rep 395
higher octane should be fine so long as you make sure it's unleaded fuel. I mix it in at times when I can find it just to try to get a 93 octane mix since all we get here in LA is 91.
'07 e92 335i (sold)
'08 e90 M3 (sold) '15 M235i |
08-18-2008, 10:36 AM | #3 |
28
Rep 211
Should have no problems at all!Here in the UK we have BP Ultimate 102 Ron at some pumps and that is excellent if not a tad expensive($8.00 a litre at todays exchange rate!)
08-18-2008, 12:32 PM | #5 |
285
Rep 6,007
I'm just guessing here. But I'd think there would be very little benefit if any at all. The engine was not tuned by BMW for 110 octane fuel so I would think it's not going to take advantage of the higher octane fuel. I am positive you will lose some HP with 87 octane and the computer will back of timing to not allow knocking. You might see a little gain with the race fuel as it will burn slower. You will not cause any damage to the car, just your wallet when you go to pay for the more expensive fuel.
08-18-2008, 12:53 PM | #6 |
Moderator
94
Rep 1,920
PencilGeek got +14hp with 100 octane vs. 91 octane. I guess the DME will adapt to the higher octane. How much remains to be seen. At some point, there is no gain...the DME cannot advance timing infinately, so there is a max benefit somewhere. Whether that be 93 octane, 95, 100, or somewhere else is the question.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
08-18-2008, 01:19 PM | #7 |
73
Rep 610
I asked this question based on pencilgeek's results. I was thinking of mixing 93 with 110 to get to around 100. I was just afraid that if I run much higher than 100 and the engine is running rich then I could possibly have the engine running too hot.
08-18-2008, 01:31 PM | #8 | |
26
Rep 395
'07 e92 335i (sold)
08-18-2008, 03:40 PM | #9 |
41
Rep 644
as long as you run UNLEADED race gas it will be fine....I tried some 100 octane & there is an improvement!
Brian
2008 E92 M3, MR, DCT, extended BB leather, loaded! 1988 Porsche 928S4, Guards red/Champagne leather 1989 Porsche 928S4 track beast!!! |
08-18-2008, 04:27 PM | #10 | |
Moderator
94
Rep 1,920
Higher octane, even 110, etc. won't cause a problem as long as it is UNLEADED.
08-18-2008, 07:47 PM | #11 |
50
Rep 604
I've heard that mixing methanol with the gas can give 100oct, In Guatemala gas is the worst, so someone told me he had done this to his Cupra R, it's just a tank of methanol and it mixes with the gas before combustion and it gives you 100oct or whaatever octane you want, do you guys think this is a safe mod??? The only doubt we had was if the car could recognized the higher octane, and since it does do you think there's any drawbacks? any info woul really help since I was tempted to do it but wanted expert opinion, and I see some of the board members are experts, thanks
08-19-2008, 10:11 AM | #12 | |
Moderator
94
Rep 1,920
I have also heard of people using Acetone, Toluene, etc. I think the major issue is not with the additive per se (as most "octane boosters" are basically comprised of this stuff), but with the purity. The crap you buy from Home Depot, etc. is not "pure". If you could get some laboratory pure stuff, then maybe...but personally, I would not risk it. I am not a Chemist, so I don't think I would go down that road based on what some numbnuts said on the net!
08-19-2008, 11:19 AM | #13 |
374
Rep 8,033
I don't see why your engine would run richer with higher octane fuel. The ECU should change ignition timing only, and not the air/fuel mixture.
08-19-2008, 12:14 PM | #14 |
Moderator
94
Rep 1,920
The ecu will adjust timing, but it does also adjust your A/F mixture...that is what the O2 sensors are for. However, as long as you don't contaminate the O2 sensors (with leaded fuel, etc.), they should function properly and keep you at ideal A/F ratios all the time...octane levels would not effect this.
08-19-2008, 12:25 PM | #16 | |
374
Rep 8,033
08-19-2008, 12:35 PM | #17 |
Moderator
94
Rep 1,920
I don't think there is a relationship between A/F ratio and octane...I thought I said that in my last sentence...maybe not.
08-19-2008, 12:39 PM | #18 |
285
Rep 6,007
I can't imagine being able to notice the difference of 14hp gain as Pencilgeek got. Of course it can be measured, and if you are on the track. But driving on the street in a 414hp car compared to possibly a 428hp car can't really be that noticeable. Can it?
08-19-2008, 12:53 PM | #19 | |
374
Rep 8,033
Anyway, there actually may very well be an indirect relationship. Maybe a richer mixture will be more likely to knock, and in the presence of higher octane, mixture can be made richer for more power. However, there are many other relationships between mixture and efficiency and emissions, and I would assume those would dictate mixture more than anything else.
08-20-2008, 10:02 AM | #20 |
Moderator
94
Rep 1,920
I agree. I wouldn't think you would notice a difference.....However, things like throttle response, etc. can be felt. That may enhance the feeling of more power...I dunno.
08-20-2008, 11:39 AM | #21 |
41
Rep 644
Pencilgeek got a 14hp gain with 100 octane (same gas I buy)....but he also got a 17hp gain with the evosport pulley and Gruppe M intake....so in theory a M3 with the pulley, intake and 100 octane would be about 390whp....
Brian
08-20-2008, 04:31 PM | #22 | |
815
Rep 7,887
The noticable difference would be the torque gain in the lower rpm range,right where you can use it.14 hp at the top end you would never notice in the a seat of the pants test.Torque is good |
