Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Just over 2000 miles and my M340i already needs a quart of oil
      08-19-2019, 01:31 PM   #1
PandaMobile
PandaMobile's Avatar
Drives: 2020 M340i TB II
2020 BMW M340  [0.00]
I have been told that BMW does burn oil. But This seems a little soon for a new car. Can someone let me know if this is normal for BMW?.
      08-19-2019, 01:47 PM   #2
claykin
Drives: various BMW
Are you very aggressive on the accelerator? Even so, with a BMW 6 cyl you shouldn't need more than 1 qt between 10K change intervals (my last 3 BMW 6 cyl engines did not consume oil). Your car has the newly revised O1 version of the B58 so maybe things are (sadly) different?
Anyway, not a good sign. Have it checked.
2023 840GC | 2021 740i | 2019 X3
      08-19-2019, 01:59 PM   #3
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
Agreed. Not a particularly good sign.
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
      08-19-2019, 02:22 PM   #4
DonTheDon
16
Drives: M340i, 340, mustang
I'm at 4800, always flooring it, still fine on oil. Needing it at 2k is definitely abnormal.
      08-19-2019, 02:24 PM   #5
PandaMobile
For the most part I was mostly city miles. I spend a lot of time in traffic.
      08-19-2019, 02:45 PM   #6
TheObviousChild
TheObviousChild's Avatar
322
Drives: '23 M3 Comp xDrive - '21 X3M40
May have started low?
On my F30 340, I have to keep a quart handy...Seems like once every 1 or 2 years, I need to top it off. Have heard the turbo is part of the reason it eats through it a bit quicker.
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      08-19-2019, 03:13 PM   #7
claykin
Drives: various BMW
Maybe, but the B58 O1 variant I recall has a more advanced cooling system for the turbo. So, shouldn't be that...
      08-19-2019, 03:15 PM   #8
claykin
Drives: various BMW
Please try an iDrive oil measurement and see if you're still topped off.
      08-19-2019, 03:55 PM   #9
Weiner0123
Weiner0123's Avatar
417
Drives: 2020 m340i. 2013 328i
That's weird I think there's something wrong, Did you follow the correct break in procedure I'm at 5K KM and I go for aggressive drives here and there and my oil has always been at full line, According to the owners manual;
      08-19-2019, 04:07 PM   #10
E39hijinks
E39hijinks's Avatar
70
Drives: 2016 Lexus
Welcome to the wonderful world of german cars. BMWs are hit or miss through out the years. Some burn, don't burn, burn this much, that much. Some burn new, some burn when old. Luck of the draw. Break-in, in your case, might have something to do with it. Not much you can do but add oil and monitor it. If it bugs you, take it to the dealer.
      08-19-2019, 04:13 PM   #11
HighlandPete
6659
Drives: BMW F11 535i Touring
Does this 'time in traffic' include a lot of idling? Has the car had a good break-in regime, or a lot of time in traffic?
Could be a clue to burning oil.
      08-19-2019, 05:44 PM   #12
DonTheDon
16
Good call. Thought it'd update automatically, didn't though. Says i need a quart
Thanks for the heads up!
      08-19-2019, 08:23 PM   #13
claykin
Drives: various BMW
Glad I helped you discover what you probably didn't want to know.
Is this B58 O1 an oil burner? Or early builds of it?
      08-19-2019, 11:39 PM   #14
miked1999
Drives: 2020 M340i
2020 M340i  [0.00]
mine did the exact same thing... needed a qt of oil after around 2K miles. I filled it up about a month ago and so far no issues since. But I drive it like I stole it when traffic is light and conditions (generally) safe and no I've not adhered to the break in guidelines in any capacity so not terribly surprised she needed oil so soon.
      08-20-2019, 03:33 AM   #15
Eagle Creek
Part of the bimmer family!
Eagle Creek's Avatar
Netherlands
139
Drives: BMWG20; BMW E90
2019 G20 330e  [0.00]
Originally Posted by miked1999 View Post
and no I've not adhered to the break in guidelines in any capacity.
Why wouldn't you do this while knowing it's better to do so?
“You can put wings on a pig, but that doesn't make it an eagle.”
      08-21-2019, 06:19 AM   #16
mathys
mathys's Avatar
197
Drives: G82 - G01 - F56
Except for pure M engines, I think breaking in the engine is not needed anymore with current production methods.
Just my 2 cents though.
      08-21-2019, 07:17 PM   #17
PandaMobile
Oh here's a feature that's standard. A place to put your quart of oil
      08-22-2019, 07:06 AM   #18
gofast182
615
Drives: 2020 M340i xDrive
Not that it's the same engine but a good friend had a 435i. It needed oil added within the first few thousand miles and never needed it again after that.
      08-22-2019, 09:29 AM   #19
themnmd
themnmd's Avatar
Drives: 23 X5MC
i would top it off and keep an eye on it. if it goes through another quart in the same millage or less, i would get it checked.
      08-22-2019, 11:03 AM   #20
PandaMobile
I put in a quart on the 23rd of July it is now August 22nd and I measured this morning and its a quarter before I have to add another quart.
      08-22-2019, 03:06 PM   #21
themnmd
themnmd's Avatar
Drives: 23 X5MC
One quart per month is too much
Appreciate 2
      08-22-2019, 04:01 PM   #22
Weiner0123
Weiner0123's Avatar
417
Honestly OP I would take it back man, piston rings probably.. go get a new motor lol there's no reason it should be burning that much oil this early,
Appreciate 3
Search this Thread:
Advanced Search
g20
