BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Hood release cable casing cracking
      08-18-2019, 05:32 AM   #1
bluewater328
Drives: 2011 bluewater 328i LCI sedan
So pic says it all. I've since wrapped it in oem wire harness wrap. So 1) is this impending doom or am I worrying about nothing 2) Will wrapping it mitigate any issues? or 3) is the part and install easy enough that I should just do it?
      08-18-2019, 07:48 AM   #2
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
They all do it. You can replace but it’ll just happen again. Easy to replace if you really feel the need to. Put it low down on the priority list.
Appreciate 2
Thorin117.50
      08-18-2019, 11:23 AM   #3
bluewater328
Originally Posted by NinetyEight740 View Post
They all do it. You can replace but it'll just happen again. Easy to replace if you really feel the need to. Put it low down on the priority list.
So you're saying wrapping it has fixed this for the time being?
Install does seem straight-forward. Thanks.
      08-19-2019, 12:53 PM   #4
mecheng77
mecheng77's Avatar
1006
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
I just usually oil the metal when I see this, the oil will hopefully seep into the cable
      08-19-2019, 12:55 PM   #5
bluewater328
Hadn't thought about that. Thanks!
      08-19-2019, 01:08 PM   #6
Seppi18
Drives: E90
+1
      08-19-2019, 01:26 PM   #7
banglenot
banglenot's Avatar
Drives: 2007 328xiT
If the driver-side cable can be separated from the latch side, in the box, you might try a long piece of 3x shrinkfit on the cable. 3x has a very large shrink ratio when heated. Effectively replace the cable jacket.
2007 530I, 2007 328xiT
2003 325XI (gone) 2004 530I (gone) 2001 530I (gone)
BMW CCA Member 15+ Years
